1Back to top Go down   Crank cover and rad hose Empty Crank cover and rad hose Thu Jan 06, 2011 7:40 pm
87m6chris
87m6chris
I've removed the crank and valve covers so I can strip them and re-paint, how do I remove the coolant hose from the crank cover without destroying it?
Also, has anyone found a cheaper oil filter wrench than BMW?
Thanks,
Chris
2Back to top Go down   Crank cover and rad hose Empty Re: Crank cover and rad hose Thu Jan 06, 2011 9:17 pm
WayneDW
WayneDW
There are non-BMW oil filter wrenches on ebay.
http://www.fossilapostles.com
3Back to top Go down   Crank cover and rad hose Empty Re: Crank cover and rad hose Thu Jan 06, 2011 10:37 pm
elle
elle
Hi i replaced my hose without removing case , due to the bend being virtually flat when i bought her.Was easy and new hose was a £10 bit of washing up liquid on outer before replacing made job a lot easier.
pete
4Back to top Go down   Crank cover and rad hose Empty Re: Crank cover and rad hose Thu Jan 06, 2011 11:00 pm
Hi elle,
Dependant upon mileage a replacement hose can be a good idea since if they do burst you are in a bit of a pickle, especially when it is miles from anywhere.
5Back to top Go down   Crank cover and rad hose Empty Re: Crank cover and rad hose Fri Jan 07, 2011 12:11 am
club_c
club_c
I hit mine with some pentetrating oil at hand, twist as you pull. Same in reverse to reinstall.
6Back to top Go down   Crank cover and rad hose Empty Re: Crank cover and rad hose Fri Jan 07, 2011 3:13 pm
By all means use penetrating oil to get it out but when replacing use washing up liquid not oil so as to protect the new rubber hose from the effect of the oil.
