Number of posts : 4301
robmack wrote:Possible that the gear indicator circuit card in the OEM gauge is broken. Run the following test.
1. Temporarily disconnect the clutch switch from the harness
2. Turn on the Ignition. Put the bike in first gear
3. Measure the voltage on Pin 5 (Black/Green) on the cable connected to the back of the OEM cluster.
If you measure 10V or more, then it's a sure sign the GPI board is defective.
Even if the clutch switch is shorting then that still shouldn't illuminate the neutral lamp.
If things worked that way then the N lamp would illuminate every time that you pull in the clutch to shift gears.
If the gear indicator shows something other than zero and that lamp is on then it's a GPI circuit board gone bad.
