1Back to top Go down   Sent the wrong fluid! Empty Sent the wrong fluid! Sat Feb 04, 2023 6:35 pm
fishboy316
fishboy316
Got the wrong fluid from amazon. Is fork oil the same as shock fluid? ( think I know the answer)
2Back to top Go down   Sent the wrong fluid! Empty Re: Sent the wrong fluid! Sat Feb 04, 2023 8:41 pm
A quick check says yes, they are the same.
I used to use ATF for front forks back in the day when I was permanently penniless as it was the equivalent of 15 weight, but not quite as froth resistant.
3Back to top Go down   Sent the wrong fluid! Empty Re: Sent the wrong fluid! Sat Feb 04, 2023 10:53 pm
fishboy316
fishboy316
Thanks Dai, I thought so just wanted to make sue. I am rebuilding my works performance shock.
Thanks again
