1Back to top Go down   Frame to engine bushes Empty Frame to engine bushes Sun Mar 26, 2023 11:04 am
Jibe
Jibe
Hi as anyone found a cheaper alternative for the front frame mount bushes ??? Been looking but can't seem to find anything apart from the real deal which are double expensive for what they are .....???
2Back to top Go down   Frame to engine bushes Empty Re: Frame to engine bushes Sun Mar 26, 2023 11:38 am
I'm sure that there are usable bushings available from automotive aftermarket suppliers.  I would guess that if you had the ID, OD, and length dimensions a replacement could be found.
https://www.suspension.com/universal-bushings.asp
3Back to top Go down   Frame to engine bushes Empty Re: Frame to engine bushes Sun Mar 26, 2023 12:27 pm
Jibe
Jibe
I've no idea of the measurements unfortunately.
4Back to top Go down   Frame to engine bushes Empty Re: Frame to engine bushes Sun Mar 26, 2023 5:24 pm
You have to take the old bushing out to put the new one in.  Take it out, measure it, and order a new one.
You know the ID is the bolt that goes through it, and it shouldn't be that hard to make a very good estimate of the length.  Measuring the OD of the frame tube the bushing is inserted in and subtracting the wall thickness should give a pretty good idea of the required OD.  I'm going to guess that the wall thickness is the same as the tubes you hacked off the rear of the bike.
I doubt that even BMW would go so far as to use a custom bushing for that application.
As a service to your fellow K bike owners, when you are done you could post a photo of your old bushing and it's dimensions.
5Back to top Go down   Frame to engine bushes Empty Re: Frame to engine bushes Sun Mar 26, 2023 6:43 pm
The rubber bushing was used to damp fairing vibrations. It wasn't used on naked K100 models, as the attached service bulletin extract implies, nor on K75 naked models. Jibe's Brick has been resurrected as a naked model. Perhaps all that is needed is a sleeve to accommodate the bolt within the frame eye and shimming to equalize space between the engine and the front frame members. There is also this fabrication discussion about which Jibe could PM the original author concerning its success and availability.
Frame to engine bushes Scree235
