1 bulb monitoring relay box indicators Thu Apr 27, 2023 1:58 pm
firstle
its just vibrating but no indicators , sounds like its trying to work , its the green type box , any ideas where to start ?
Is this the box containing the board which you cut for installation of LEDs, as described in this post, firstie?firstle wrote:its just vibrating but no indicators , sounds like its trying to work , its the green type box , any ideas where to start ?
Pin 31 is the main ground for the flasher relay. The ground from the hazard switch has minimal current to ground via the W pin as it is just the trigger for hazard mode of the flasher relay.daveyson wrote:If the hazard lights work normally, I will also guess that the problem is a poor earth to the flasher unit, because the hazards get earth from the hazard switch. Pin 31 is earth. It's best to find the fault before fixing it, but sometimes I just get lazy and try a quick fix, like say giving the unit and it's holder a clean and a spray of electrical contact cleaner, that might fix it. While you're there, might as well give the others a clean too.
Power is from fuse 7 for the indicators, and fuse 3 for the hazards.
Blue lights is my guess.firstle wrote:will take a look later , i have noticed it also has a 12v lucas flasher unit instaled next to the standard unit but have no idea what that one does , bike is ex police/blood bike
K100-forum.com » Technical, repair and troubleshooting » Electrical » bulb monitoring relay box indicators
Similar topics
