1Back to top Go down   [WTB] K75/K100 seat latch Empty [WTB] K75/K100 seat latch Thu May 04, 2023 6:48 pm
I need a new seat latch for my K75 (#8 in the picture below).  It has a broken catch so the seat won't latch shut.  Anyone have a spare to sell?
[WTB] K75/K100 seat latch Screen13
2Back to top Go down   [WTB] K75/K100 seat latch Empty Re: [WTB] K75/K100 seat latch Thu May 04, 2023 7:16 pm
I have a complete latch somewhere which I don't need although it does not have a key.  It came with a batch of stuff and is in good condition.
I can post it unless you find one closer, with a key.  Don't want anything for it.
3Back to top Go down   [WTB] K75/K100 seat latch Empty Re: [WTB] K75/K100 seat latch Thu May 04, 2023 10:09 pm
Bricklayer
Bricklayer
If you get stuck and nothing comes through I had repaired one using a paperclip, epoxy and a bit of tender filing. So if your in a jam I could make a sketch the process.
Anthony Mrugacz
https://anthonymrugacz.net
View Past Stable of Ponies:
1978 Suzuki TS185
1976 BMW R90/6
1973 Yamaha LT3-MX
1970 BMW R75/5
1970 Suzuki T500
https://anthonymrugacz.net/
4Back to top Go down   [WTB] K75/K100 seat latch Empty Re: [WTB] K75/K100 seat latch Fri May 05, 2023 4:08 pm
Bricklayer wrote:If you get stuck and nothing comes through I had repaired one using a paperclip, epoxy and a bit of tender filing. So if your in a jam I could make a sketch the process.
The hook portion of the catch has broken off and looks like it won't be easily repaired. You can see that in the picture below. [WTB] K75/K100 seat latch Img_0012
5Back to top Go down   [WTB] K75/K100 seat latch Empty Re: [WTB] K75/K100 seat latch Fri May 05, 2023 4:09 pm
TacKler wrote:I have a complete latch somewhere which I don't need although it does not have a key.  It came with a batch of stuff and is in good condition.
Thank you for that offer Tackler. I think I have a line on a latch from a local guy. I'll let you know if I manage to obtain one locally.
6Back to top Go down   [WTB] K75/K100 seat latch Empty Re: [WTB] K75/K100 seat latch Fri May 05, 2023 9:48 pm
Bricklayer
Bricklayer
In post 4's image, this exactly how mine broke. If you see it is grooved, this is were I used a paperclip to strengthen it.
 Here's how I repaired mine, epoxy is frustrating to use on small projects.
1) small amount of epoxy to glue it back together, let cure over night.
2) cut and bend a paperclip to fit in the groove.
3) using more epoxy fill in the groove and all around like a cast, let cure overnight
4) dremel or small file to return to close to original form but leaving enough epoxy to hold it together
I always place an item over the latch so the metal latch doesn't break the repair if the seat falls shut. Also, I ALWAYS push in the button mechanism before closing the seat.
I am probably not going to take the seat lock and latch apart for a photo op....
Anthony Mrugacz
1978 Suzuki TS185
1976 BMW R90/6
1973 Yamaha LT3-MX
1970 BMW R75/5
1970 Suzuki T500
7Back to top Go down   [WTB] K75/K100 seat latch Empty Re: [WTB] K75/K100 seat latch Sat May 06, 2023 5:48 pm
I met a guy today who gave me a couple of (useless to him) latches. They had defective locks but everything else was intact and working. So I swapped out my broken parts for working parts. Everything is back to normal again.
8Back to top Go down   [WTB] K75/K100 seat latch Empty Re: [WTB] K75/K100 seat latch Sat May 06, 2023 8:34 pm
[WTB] K75/K100 seat latch 112350
9Back to top Go down   [WTB] K75/K100 seat latch Empty Re: [WTB] K75/K100 seat latch Thu May 11, 2023 3:28 pm
Bricklayer
Bricklayer
The Great Pumpkin put a kabosh on mine today as my repair failed. It's supposed to fail at the end of riding season- aaargh...
My backup plan is a piece of chain which drops down and hooks onto the helmet look. Tape is to reduce frame scratchin'.
[WTB] K75/K100 seat latch Seat-c12
Anthony Mrugacz
1978 Suzuki TS185
1976 BMW R90/6
1973 Yamaha LT3-MX
1970 BMW R75/5
1970 Suzuki T500
