1Back to top Go down   K75 Speedometer not working Empty K75 Speedometer not working Tue May 09, 2023 9:52 pm
jjefferies
jjefferies
My Red 1991 K75 had been sitting for a spell while I've been using the Silver K75. No particular reason but today I thought to take Red out for a ride. First thing I noticed was that the speedometer was not working nor was the odometer. Tach and all the other instruments were working correctly. My initial assumption/guess was that corrosion was interfering with the signal from the rear wheel pickup. And if the speedometer wasn't working then the odometer would not either. This must have occurred while Red was sitting in the garage out of the weather as I don't remember any such issues when I last put Red away.
Returning home I took the instrument pod off the bike and using a electrical cleaner sprayed and cleaned the connectors and the pins from the instrument pod. Reconnecting the instrument pod to the connectors I started the bike and with it on the center stand ran it through the gears, i.e. I mean that I had the rear wheel racing quite fast. Still no movement from the speedometer. So I checked the rear wheel pickup. Not much to see or check  but I pulled it and cleaned it and re-inserted it. No change in the symptoms. I have another instrument cluster from the current project an '86 K100 and so substituted it for the K75 instrument pod. Symptoms remained the same. Other instrument lights, tachometer etc work but not the speedo. Now the K100 may or may not be totally functional and a complete swap for the K75. Though I would have thought they (K100, K75) are the same. I did note that the K100 instrument pod gear indicator not working.
My reading of the Haynes and Clymer manuals electrical schematics indicate to me that the circuit between rear pickup and speedometer are rather simple, two wires. But
1. Has anyone else run into this problem? Your findings?
2. Any pointers to how to discern which pin is which on the two instrument pod connectors? I would like to ring out the circuitry for shorts and check resistance of the pickup.
3. Suggestions of things to look at or try?
thanks and best regards
J.Jefferies
2Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Tue May 09, 2023 10:49 pm
Hold an electric soldering iron next to the sensor at the rear drive. I think Canada uses a 50Hz supply so it should read 61KPH.
I have had to remove the sensor sometimes to get it to work.
3Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Tue May 09, 2023 10:52 pm
jjefferies
jjefferies
Rick G wrote:Hold an electric soldering iron next to the sensor at the rear drive. I think Canada uses a 50Hz supply so it should read 61KPH.
Interesting approach. I've also been told to clean the connector under the right battery cover. The one that sits next to the fuel pump connector. Will be doing that tomorrow as well.
4Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Tue May 09, 2023 11:22 pm
I think the cable from the speed pickup is routed near the right foot peg plate.  There is a chance it is pinched or otherwise damaged there.
5Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Tue May 09, 2023 11:29 pm
US and Canada are 60 Hz.
And not all soldering irons put out enough of a magnetic field for the K speedo sensor. I have some that will and some that won't. Not sure why.
6Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Tue May 09, 2023 11:39 pm
A lot of soldering irons have resistive heating elements so they will not have a noticeable magnetic field.  Weller soldering guns use a step down transformer and send low voltage high current through the heating element.  They will activate the speed pickup when it gets into the field of the transformer.
7Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Wed May 10, 2023 12:23 am
jjefferies
jjefferies
Point-Seven-five wrote:A lot of soldering irons have resistive heating elements so they will not have a noticeable magnetic field.  Weller soldering guns use a step down transformer and send low voltage high current through the heating element.  They will activate the speed pickup when it gets into the field of the transformer.
Now that is useful information as I have a Weller soldering gun.
thanks .75
8Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Wed May 10, 2023 4:58 am
JGT
JGT
I have concluded that the speedo on my K75 is temperature sensitive.
If I start my ride with the outside temperature below 10 Deg C the speedo and mileometer will not work for 3 to 4 miles then lazily begins to work normally. A warmer day everything works straight away.
The tachometer is unaffected what ever the temperature.
1992 K75
9Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Wed May 10, 2023 7:12 am
In lieu of a soldering iron, if you have a PC with a sound card, you can try Karamba to debug your speedometer.  Look through my Karamba / K-diag tutorial (https://www.k100-forum.com/t2038-karamba-speedometer-calibration-program-tutorial#14208) to find out more.
There is a two-pin connector under the right battery cover where the sensor plugs into the harness. Try cleaning that and reseating the connector a few times to improve contact. The speed signal is very low amplitude and any corrosion will degrade the signal.
10Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Wed May 10, 2023 7:51 am
Rob, I need to put Karamba on my "new" laptop, but haven't been able to do it for several years now because as I recall it has been behind a paywall of some sort.  Do you know any way around it?
11Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Wed May 10, 2023 8:27 am
Hi Jim, Karamba was replaced several years ago by K-diag. K-diag does everything Karamba does plus more (with the right hardware adapter). K-diag is available for download for free from the Technical Resource Centre on this site.
12Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Wed May 10, 2023 10:46 am
Point-Seven-five wrote:Rob, I need to put Karamba on my "new" laptop, but haven't been able to do it for several years now because as I recall it has been behind a paywall of some sort.  Do you know any way around it?
Here's a link to Karamba:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/speedocal/Karamba.zip
13Back to top Go down   K75 Speedometer not working Empty Fixed?? Wed May 10, 2023 2:50 pm
jjefferies
jjefferies
I cleaned the two pin connector. It was pretty bad in there so I hit it with a lot of the spray electronics cleaner. Connected the instrument pod up and cranked the bike. And now the speedo is working again. Thanks all. I'll try and download the diagnostic software and see what it can do.
JJefferies
14Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Wed May 10, 2023 2:56 pm
jjefferies
jjefferies
robmack wrote:Hi Jim,  Karamba was replaced several years ago by K-diag.  K-diag does everything Karamba does plus more (with the right hardware adapter).  K-diag is available for download for free from the Technical Resource Centre on this site.
robmack, could you translate this to a link? I didn't find the "Technical Resource Centre" on www.k100-forum.com.
15Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Wed May 10, 2023 6:22 pm
Here's the K-diag link:   https://www.kforum-tech.com/Karamba/K_DIAG.zip
Go to the "Portal" page of the K100-forum site and locate the link "K100 Forum Tech Page". Click on it and accept the disclaimer. You'll come to this page and K-diag is highlighted with a RED box in the picture below.
K75 Speedometer not working Screen14
16Back to top Go down   K75 Speedometer not working Empty Re: K75 Speedometer not working Wed May 10, 2023 7:13 pm
Thanks, Rob!!!!
Looks pretty cool.  Will have to spend some time this evening playing with it.
