3 Re: Fuel Tank Leaking Mon Sep 05, 2022 6:53 pm
4 Re: Fuel Tank Leaking Mon Sep 05, 2022 6:55 pm
That picture is of the early type you will find the correct O-ring from 86 onward. I cant recall the size but Real OEM will give you the size.
5 Re: Fuel Tank Leaking Sat Sep 10, 2022 12:58 pm
RealOEM doesn't list the size of the O-ring that seals the fuel sender unit. I checked the Canadian price for the original BMW part and BMW want $23.00 plus HST. For an O-ring!! Highway robbery!
As far as I can tell, the correct size metric O-ring should be 4.5x45. That has a cross-section of 4.5mm, OD of 54mm and ID of 45mm. This is eye-balling it; can anyone else confirm?
6 Re: Fuel Tank Leaking Sat Sep 10, 2022 2:38 pm
7 Re: Fuel Tank Leaking Sat Sep 10, 2022 3:24 pm
8 Re: Fuel Tank Leaking Sat Sep 10, 2022 4:52 pm
There's no spec for that torque in the BMW manual. Just get them nice and tight.
9 Re: Fuel Tank Leaking Sat Sep 10, 2022 5:51 pm
Laitch wrote:Euro Motoelectrics confirms.
10 Re: Fuel Tank Leaking Sat Sep 10, 2022 6:37 pm
FYI: Found a good source for these O-rings on Aliexpress. 5.0mm CS instead of 4.5mm, but they are Vitron which is good if you're using E10 fuel.
Search for this title "CS 5mm OD16-100mm Green FKM Fluorine Rubber O Ring O-Ring Oil Sealing Gasket" to get to the product. If I posted a link, it would probably be broken in a couple months.
UPDATE: Received the o-rings from Aliexpress in the mail. They fit perfectly and the slightly extra thickness helps to seal a little better than an OEM o-ring (5mm versus 4.5mm).
11 Re: Fuel Tank Leaking Tue Aug 08, 2023 11:35 am
taube
Having the same issue as the OP
My tank is leaking from this plate, so I ordered the replacement o-ring from EuroMotoElectrics.
I also found the FKM Viton O-Rings robmack mentioned on Aliexpress, so I've ordered '55mm OD x 5mm thickness'. Yes I'm buying a redundant part, but it's very cheap, and AliExpress takes ages to ship anyway.
Restoration project: 1988 BMW K100RS
Currently riding: 2019 Honda CBR300R
12 Re: Fuel Tank Leaking Tue Aug 08, 2023 2:10 pm
I get my o-rings at the industrial bearing shop. Viton for about $3. They have them in stock, no waiting. You should find your local shop. Good prices on bearings, too.
13 Re: Fuel Tank Leaking Tue Aug 08, 2023 3:01 pm
IainM
I had the same leak from the fuel sensor plate which was easily fixed by cleaning the mating surfaces and replacing the O-ring. It has been fine since and this was ~ 5 years ago.
Iain
Iain
14 Re: Fuel Tank Leaking Sun Aug 13, 2023 2:20 am
taube
Alright, I replaced the o-ring and it stopped the leak from my fuel level float plate.
As Iain noted, cleaning the mating surfaces helped tremendously. My sender
unit accumulated a lot of rust... I think the old o-ring might have been fine, but it could no longer seal after being disturbed because the surface was so rough. Photo is before a WD-40 and wire brush treatment.
15 Re: Fuel Tank Leaking Sun Aug 13, 2023 2:30 am
bad boy
taube
looks like your K needs quite a bit of TLC
I wish you lots of success
Cheerz, David
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Fuel Tank Leaking
Similar topics
