1 Idle speed. Fri Apr 15 2011, 04:03
BooG
My engine is idling at 2000rpm. After I put a new fuel pressure regulator on and mended a leaky crankcase breather hose, the idle speed has risen. How do I reduce the idle speed? A correct procedure would be appreciated. Am also loosing a little coolant, but I'm not sure where its from. Can't spot an obvious leak anywhere, but, i can spot a small leak from the bottom of the engine, but thats not where the leak appears to be (if you get me)??
