1Back to top Go down   the watches are well lit Empty the watches are well lit Tue Apr 03, 2012 4:49 am
komandoalicante
komandoalicante
Well some of you already know my mania to make the watches are well lit
This is a simple and cheap
We did a system concept of this but with blue LEDs were not very good.
the watches are well lit Cimg3691t
the watches are well lit Cimg3696
The diodes and resistors have cost € 3.45 and also we must shrink sleeves in my case of 2 diameters
Note that the diodes have the longest polarity is negative
the watches are well lit Cimg3697y
the watches are well lit Cimg3700y
the watches are well lit Cimg3701z
the watches are well lit Cimg3702i
the watches are well lit Cimg3705o
the watches are well lit Cimg3706b
the watches are well lit Cimg3709f
The first case (left) isolates the terminal of the diode and resistance, then we put a cover and isolate the other diode terminal taking it back, then we put the other case we weld the diode resistance and isolate the remaining aa sight.
the watches are well lit Cimg3710y
the watches are well lit Cimg3711q
the watches are well lit Cimg3712
the watches are well lit Cimg3719h
the watches are well lit Cimg3720
the watches are well lit Cimg3722a
I have passed under the wire by passing it through the hole, so when goals faston connector cable firmly subject, so installation is very easy to undo.
the watches are well lit Cimg3723x
I have soldered the negative terminal of the diode to the chassis and so put him to ground and clamping circuit that does not move.
the watches are well lit Cimg3726
the watches are well lit Cimg3727d
SAK3 and komandoalicante is the same person
In March we made a International meeting  KEDADA ALICANTE of BMW motorcycle K in  Spain.
The last meeeting  March 2020
https://youtu.be/hfqxlGeEVsY
https://picasaweb.google.com/100417997445250027277
2Back to top Go down   the watches are well lit Empty Re: the watches are well lit Tue Apr 03, 2012 4:53 am
white much better ....thanks
3Back to top Go down   the watches are well lit Empty Re: the watches are well lit Tue Apr 03, 2012 10:09 am
beanoldboy
beanoldboy
and for you for this also i am thankful . although easy for some , these simple instructions are gold for those not yet initiated to heat shrink . very nice, and yes white is better.
http://www.airware.com.au
Similar topics
» While illuminating watches
