1 Sparkplugs aren't firing on my RS...[SOLVED] Tue Jul 24, 2012 1:04 pm
TSBT
...and my Motronic is making some funky noises.
Took on a big project beginning of June: repainted fairings, replaced main seal, clutch plate/o-ring, spline lube, breather hose, air filter, also replaced cracked throttle-body breather hose (see attached) with a temporary hose until new one arrives - cut a piece from previous engine/breather hose, stupid? Figured it was for air, maybe. Got a new one on backorder. Also replaced crankshaft seal, Dielectric greased all connectors, put the key in annnnd there's no spark.
The starter turns over nicely, cluster lights up everywhere, got a fuel reading, headlight, motronic clicks from ABS sensor needing reset, then started clicking consecutively which is weird.
Says it's something Ignition related in Clymers troubleshooting guide, however I don't remember messing with the ignition. Had the starter out but put it back the way I found it after cleaning connections...I'll keep at it.
Chris
