1Back to top Go down   unclear about front forks Empty unclear about front forks Mon Aug 13, 2012 1:23 pm
ridefar
ridefar
I changed the front fork seals on my 1989 K100rs. Looked in the Clymers manual for fork oil capacity to find more than one choice. So I tried the lower amount with Belray 10 wt that I had on the shelf. The problem is that oil is leaking past the new seals. Stopped by the BMW dealer to ask. They said that it is possible but did not know for sure that the oil could be different in each fork. Anyone know what amount of oil to use in these forks?
2Back to top Go down   unclear about front forks Empty Re: unclear about front forks Mon Aug 13, 2012 1:39 pm
Ridefar,
I have the Clymer manual but a lot of bikes have had changes to the front end. Can you put up some photos? I did notice that for some versions the right and left are not identical.
92KK
3Back to top Go down   unclear about front forks Empty Re: unclear about front forks Mon Aug 13, 2012 9:03 pm
It is very easy to damage the seal lip when reassembling those forks. This is most likely what has happened.
I am presuming yours is a 16valve model and so the forks will take 400ml if you have had the forks apart and drained them completly, which you will need to do to put new seals in.
It is possible that you got the wrong seals as Ks have 3 different sizes of fork leg 41mm, 41.3mm and 41.7mm the latter being yours.
I use 10weight oil in my 16v and it suits me but depending on your weight and riding style you may prefer a lighter grade
4Back to top Go down   unclear about front forks Empty Re: unclear about front forks Tue Aug 14, 2012 8:40 am
ridefar
ridefar
thanks, think I had the wrong seals. New ones are on the way.
5Back to top Go down   unclear about front forks Empty Re: unclear about front forks Tue Aug 14, 2012 8:55 am
dutchie
dutchie
Maybe this could help?
unclear about front forks Fork_o14
unclear about front forks Fork_o15
unclear about front forks Fork_o16
unclear about front forks Fork_o17
grtz Dick
K75RT 1996 unclear about front forks Klettern
K100RT 1986
