1Back to top Go down   1991 K100LT Inspection Empty 1991 K100LT Inspection on Wed Oct 03, 2012 1:17 pm
mikidymac
mikidymac
I recently was given a 1991 K100LT with 108,000 miles so I just wanted to take it apart and make sure everything is good to go.
1991 K100LT Inspection Dsc_0023
1991 K100LT Inspection Dsc_0024
1991 K100LT Inspection Dsc_0025
She looks clean from the outside so I thought I would get started taking her apart. First the trailer hitch came off just because I do not have a trailer and it was heavy.
1991 K100LT Inspection Dsc_0026
Hear you can see her with most of her cloths off. Due to her life in the California desert you can see we do not have any corosion as most of you do in the more damp climates. Even after 20 years and 100,000 miles she still looks good under her skirt.
1991 K100LT Inspection 20120910
Here you can see that the foam pad under the top box was not kind to the rear fender. It had some dirt under it and did some paint damage. The plug in the muffler is there because my 2.5 year old assistand likes to put things down there to watch them dissapear. You can see the air filter sitting on the filter looks brand new. I was told the bike had everything replaced at 105,000 miles and I have the receipts too fot $3,000 in BMW parts. So far it looks true.
1991 K100LT Inspection 20120911
1991 K100LT Inspection 20120912
1991 K100LT Inspection 20120913
Here is where I found why I had no speakers or speaker wires. THe PO used some resistors so the factory radio would still use 4 Ohms per speaker when using headphones. He had the old 5 pin intercom connection so I am going to change it over to a standard 3.5mm headphone jack so I can use earbuds. It was only $4.50 at Radio Shack so I am not going to buy speakers.
1991 K100LT Inspection 20120914
Last is a picture of the wheels. You can see most of the silver paint is gone so I will be repainting them with some DupliColor Wheel Paint. You can also see how faded the red is on the front fender. It is still glossy but it has lost the red pigment.
1991 K100LT Inspection 20120915
1991 K100LT, 2004 KTM 450 EXC, 2005 Buell Blast, 2008 Polaris RZR
2Back to top Go down   1991 K100LT Inspection Empty Nice machine on Wed Oct 03, 2012 1:41 pm
DeRodster
DeRodster
Wow, well done.
Nice looking bike in great condition.
That's the benefit of living in a dry climate.
I took ownership of mine at end of August but have to say it has
not faired as well as yours in a damp climate as we have here in Ireland.
Also lying unused for a long time in un-heated storage didn't help either.
But for all of that it works as it should and is a joy to ride.
Good luck with yours.
Rod
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
3Back to top Go down   1991 K100LT Inspection Empty Re: 1991 K100LT Inspection on Wed Oct 03, 2012 2:07 pm
looking good ....enjoy !
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%O1991 K100LT Inspection Au-log10
4Back to top Go down   1991 K100LT Inspection Empty Re: 1991 K100LT Inspection on Wed Oct 03, 2012 5:36 pm
Wow , good work so far. The frame is in great shape. Im not a great fan of ear buds when riding as they block out the traffic sounds but you might also consider some of the small helmet speakers as an alternative. I'm Looking forward to the next update already 1991 K100LT Inspection 112350
1991 K100LT Inspection Ir-log1188....May contain nuts!1991 K100LT Inspection Ir-log11
5Back to top Go down   1991 K100LT Inspection Empty Re: 1991 K100LT Inspection on Wed Oct 03, 2012 7:59 pm
mikidymac
mikidymac
I either use ear plugs or noise canceling earbuds. I do not listen to the music lout so I can still hear traffic and the bike. Sometimes it is nice to have a little background noise on those long rides. I only listen to music on the long open freeways when the voices in my head get too loud.
6Back to top Go down   1991 K100LT Inspection Empty Re: 1991 K100LT Inspection on Thu Oct 04, 2012 11:12 am
Motorandy123
Motorandy123
I got some automotive touch up paint at a local discount store to paint my wheels.
I think they came out pretty good!
Before;
1991 K100LT Inspection DSCN1024
After;
1991 K100LT Inspection DSCN1296
I need to find a way to paint the body panels. I was thinking of 2 part paint in spray cans. I painted a dirt
bike tank with regular spray paint and it peeled off when some fuel leaked...
MotoRandy123
1991 K75 "Special Edition"
7Back to top Go down   1991 K100LT Inspection Empty Re: 1991 K100LT Inspection on Thu Oct 04, 2012 12:49 pm
mikidymac
mikidymac
Wheels look nice. DupliColor makes some pre mixed paint sold at auto part stores that is suposed to be easy to use and for the do it yourselfer. You could get a spray gun from Harbor Freight.
8Back to top Go down   1991 K100LT Inspection Empty Re: 1991 K100LT Inspection on Thu Oct 04, 2012 5:05 pm
mikidymac
mikidymac
So last night I had a chance to Deoxit the connections under the tank and decided to clean the left switch and found that the solder had melted and the high and low headlight wires are now always connected. Looks like the high and low have been on the same time for who knows how long. Tiday I plan to fix the solder and install the headlight relays as others have suggested.
1991 K100LT Inspection 20121012
1991 K100LT Inspection 20121013
