1Back to top Go down   [solved]Exhaust mount problem Solved Empty Exhaust mount problem Tue Apr 09, 2013 5:33 pm
ali2908
ali2908
I am struggling getting the exhaust to connect to the hanger, my bike is an 85 K I have a 87 exhaust a later foot hanger without the rubber bushes and I can't get the mounting holes to line up. I have made a plate welded to the later type exhaust bracket but you can see from the photo the exhaust is about 50mm closer to the engine than it should be. Were the earlier bikes fitted with slightly shorter exhaust pipes, because I have difficulty getting the clearance to fit the clamps and there are problems with the side stand as well.
I was thinking of grinding off the exhaust bracket along the black line in the picture to get slightly better clearance
[solved]Exhaust mount problem Solved Imag0116
Any other ideas before I start grinding?
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
That looks to me like it needs the later type of rubber mounting, if anything maybe the exhaust is 10-15 mm too high which would just push down.
ali2908
ali2908
I have the later type mount which I have welded a plate on to let it line up with the original mounting hole on the exhaust
Regards
Ali
1985 K100RS
2002 K1200 RS
AJ.Valente
AJ.Valente
I've been struggling with a similar problem, a one-bolt muffler and two bolt foot plate.
Have you tried loosening all the clamps on header pipes at the plenum and then moving the muffler around? It's a two-part process. First, assemble the heat guard and foot plate before tightening the header clamps. Second, remove the plate and heat guard again in order to tighten the final header clamp before re-assembing the same. Doing the above I got the assembly within 3/8"--not perfect but fairly close for final clean-up with a Drammel.
'98 K1200RS Marrakesh Red
My old K100 RT Pics and Mods
ali2908
ali2908
I have tried that when I pull it back to line up the hole it comes off the pipes, that's why I am beginning to think the pipes are the source of the problem.
Regards
Ali
1985 K100RS
2002 K1200 RS
MikeP
MikeP
Are you mounting it with or without this bit?
[solved]Exhaust mount problem Solved BMW%20K75S%20%2893%29-M
ali2908
ali2908
Yes it's that mount I have welded a metal plate to extend the mount towards the exhaust bracket
Regards
Ali
1985 K100RS
2002 K1200 RS
May have been in a bingle which made things a bit cockeyed but they are all the bits needed.
ali2908
ali2908
Here are some pics of how it is mounted with the welded plate
[solved]Exhaust mount problem Solved Imag0118
[solved]Exhaust mount problem Solved Imag0117
Still got clearance issues at the clamps on the exhaust pipes though.
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
ali2908
ali2908
Think I have got to the bottom of the problem. I have bought another set of down pipes from an 84 K 100 RS and these are about 2 inches longer! Looks like the PO had cut the original pipes for some reason. Now the fun begins taking of the exhaust nuts!!
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
MT350Explorer
MT350Explorer
Good detective work Ali! Sounds frustrating but be good when you get it sorted
Dave
1991 K100 RS 16 valve
Ali,
Maybe the PO couldn't get the silencer off........so he cut the pipes instead?affraid
Paul
ali2908
ali2908
Possibly, he did have the silencer hanging by a piece of building block work strap, so anything is possible.
Regards
Ali
1985 K100RS
2002 K1200 RS
spray the nuts and let them soak for at least 12 hours ali
respray if you can a few times ...wd40, rp7, anything
ali2908
ali2908
Just to give an update, managed to get 7 nuts off with a little help from a great rounded nut removal tool, but one stud snapped of bugger!! As you can see from the picture below the PO had shortened the pipes for some reason hence the problem getting the clamps and exhaust on.
[solved]Exhaust mount problem Solved 2013-010
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
MikeP
MikeP
Good result Ali.
I'd be unable to resist buffing them up now that they're all apart like that. sick
ali2908
ali2908
I'm trying!! Still thinking how to get the broken stud out, it would be one next to the engine with limited space to work in!
Regards
Ali
1985 K100RS
2002 K1200 RS
MikeP
MikeP
How much of the snapped stud is left?
ali2908
ali2908
Regards
Ali
1985 K100RS
2002 K1200 RS
MikeP
MikeP
That last type will probably be too bulky to use in the space you have.
You'd be better trying something like these:
[solved]Exhaust mount problem Solved 1149
http://www.amp-starters.co.uk/product.asp?P_ID=1149
I have a set, they're relatively small and simple to use.
Shame you are at the other end of the country, you could have borrowed mine.
ali2908
ali2908
Saw something like that, is it 8mm stud?
Regards
Ali
1985 K100RS
2002 K1200 RS
MikeP
MikeP
They are 6, 8, 10 & 12mm and they work on a cam-roller system; as you turn, they grip more. They are ½ inch drive.
A bit of heat and Bob's your proverbial.
