Number of posts : 7897
The relay would seem to be getting power the moment the ignition is turned on. Check the incoming supply wire to the relay, if it's live the moment the ignition is on then the problem is further back. If not then it would seem to be the relay itself. A simple disconnection might show this one up.
Work back from that with the first one being the connector from the handlebar controls to the loom, just checking with ignition on and off. If opening that connector does not stop the problem then it's somewhere between the connector and the starter relay.
If that does solve the problem then it would seem to be between the loom connection and the handlebar controls. Its not easy to open up that one but it can be done.
If you trace the wire back you may find a short somewhere. There are a few potential pinch points that if the cables are crushed could become problematic. In extreme cold the insulation becomes brittle and moving a bike around in freezing temperatures using full lock is hard on the insulation.
I was in under the tank in my LT and there were what appeared to be some same coloured wires and identical connectors but that were not designed to go together. I am wondering could one of these have become an issue after changing the clutch switch..?
Also in the back of my mind is the routing from the start button to the ECU, its one of two feeds to the ECU and which should only work when the start button is pressed. I don't have the answer to this one but someone else might: if there is a fault here could it affect the starter relay? The other being the Hall sensor, this one appears to be in order.
1971 Yamaha 125 YAS-1
