Number of posts : 4289
Reset procedure:
1) With the ignition turned off, ground the center diagnostic plug terminal.
2) Hold the ABS switch down.
3) Then turn on the bike (doesn't need to be running, just on) while keeping the switch depressed.
4) Count to 20 or 30 while keeping the ABS switch depressed.
If it doesn't work the first time then try it a couple of more times.
