1Back to top Go down   Mystery rumble noise. Empty Mystery rumble noise. Fri Feb 14, 2014 4:07 am
BritMotorWorx
BritMotorWorx
My recently purchased K100 which has a very obvious low pitched rumble at start up but it goes away as the engine warms up after about a minute.
  My first thought when I heard it was big end bearings but they would  not lessen as the oil thinned?    I put a large screw driver to my ear placing the driver end on different parts of the engine and it sounds like it is coming from the drive end of the motor or trans/clutch area?
Any ideas greatly appreciated!
1st time Beemer owner.
1986 K100 RT Cafe Racer
2Back to top Go down   Mystery rumble noise. Empty Re: Mystery rumble noise. Fri Feb 14, 2014 4:42 am
hi mate
if it is a pre 88 model 8 valve its likely to be the output shaft to crankshaft fixing method .these old machines used rivets to bond the hardened drive gears of the crank  to the output shaft through a rubber buffered aluminium cage to the output shaft and then to the clutch assembly cage ( think vw for a sec )
these develop some movement after many years
I believe the sharper impact ...rate of the cylinders - pistons acceleration change at cold temperatures amplifies this effect ...once the heat is up the effect is less pronounced ...and the metal has swollen a little to take up the cold temp differences on that mechanism
some have removed the output shaft and redone the fixings ...some have found a 16 valve or k1100 output shaft (which uses 12 rivets instead of the 6 usually used ) and by the way possibly nearly 10 years younger )) to repair the issue
not really an issue until the whole lot of the rivets "lets go"
if you use the search utility you will find many results  "output shaft noise "
my own engine rattles like crazy ....but change is a coming
good luck !
3Back to top Go down   Mystery rumble noise. Empty Re: Mystery rumble noise. Fri Feb 14, 2014 5:29 am
BritMotorWorx
BritMotorWorx
Thanks for the prompt reply Charlie!   You liddle beaudy mate!    Sounds like the problem alright and now can I plan to do my clutch spline lube with some more replacement parts while she's spread open, Ooops I mean split apart. bugger .... you know what I mean!    Embarassed
4Back to top Go down   Mystery rumble noise. Empty Re: Mystery rumble noise. Fri Feb 14, 2014 6:35 am
MikeP
MikeP
If you have no immediate desire to rip the motor apart, you can safely leave the rivets. Even if they fail altogether the debris doesn't get into the bores or anywhere that it can cause harm. You may be stranded with no drive but many bikes just go on tinkling away happily for the rest of their lives.
1992 K1
5Back to top Go down   Mystery rumble noise. Empty Re: Mystery rumble noise. Fri Feb 14, 2014 1:44 pm
Kyle10
Kyle10
It is likely the output shaft, but not necessarily the rivets. Rivets do go south but it's more likely the tension spring b. the output shaft gears.
There is a circular spring between the two gears that provides tension. It's held in place via a post on the gear and a small hole in the spring.
Through the years/miles the hole on the spring can become out-of-round, causing slop, slap. That's probably the rattle you're hearing.
It's a cheap part and it's an easy fix - once you've got to the damned thing. I had to remove the engine, which meant removing the trans/driveline and putting the engine on a bench upside down.
Helluva lot of work but it worked a charm and I no longer have to deal with the wincing every time I take off from start.
6Back to top Go down   Mystery rumble noise. Empty Re: Mystery rumble noise. Fri Feb 14, 2014 1:48 pm
The rivets could well be OK and the noise could be from the anti-backlash mechanism on the output gear, which, again, doesn't usually cause a problem. You can see some of the rivets if you remove the RHS engine cover.
 My rivets look OK, but I still get the dreaded cold rattle. It's been doing it for donkeys' years so I just ignore it!
In the past it would have been known as 'character'.
(Kyle10 has just posted a similar thought, but I'll leave my post)
7Back to top Go down   Mystery rumble noise. Empty Re: Mystery rumble noise. Fri Feb 14, 2014 1:54 pm
Kyle10
Kyle10
I'll be dipped. Here it is:
http://hrsbstaff.ednet.ns.ca/bvogel/K100/K100.htm
Scroll down about halfway
8Back to top Go down   Mystery rumble noise. Empty Re: Mystery rumble noise. Fri Feb 14, 2014 11:36 pm
BritMotorWorx
BritMotorWorx
Thanks guys.   I hate irritating whining, growling noises ... that's why I'm single.   Very Happy
Now I can go in knowing where to start looking as I have to remove the transmission anyway, but really hoping I don't have to split the engine.
   What a great forum, it's like having your own BMW mechanic in your office.
