1Back to top Go down   misfire help Empty misfire help Thu Mar 13, 2014 11:58 am
thumperslaw
thumperslaw
After having this on going battle with my k100lt 1986 i've still got this bloody misfire.
What i've done so far
Changed fuel pump
fuel filter
fuel lines (even in the tank)
new full loom
different injectors
fuel rail
f.i brain
ecu
switch gear
plugs
leads
coils
temp sensor
battery
+ & - battery leads
exhaust
brand new inlet rubbers (£££)
air flow
air box
head has been pulled and checked (fine)
it seems to rev clean when in (N)
but up the road when under load it's "bucking" and mis firing Sad
Help me!
K100 "ratrod" , VTR firstorm, stunted up srad 750, gsxr 750m (sold) , '86 slabby (Sold)
2Back to top Go down   misfire help Empty Re: misfire help Thu Mar 13, 2014 12:05 pm
fuel level sender connector
ignition switch
3Back to top Go down   misfire help Empty Re: misfire help Thu Mar 13, 2014 12:10 pm
thumperslaw
thumperslaw
I've changed the ignition switch twice.
Changed the fuel sender
It's mis firing on all four pipes
4Back to top Go down   misfire help Empty Re: misfire help Thu Mar 13, 2014 12:54 pm
might be time to pull the afm
take the lid off it and check-test the anvil to pin connection of the wiper plate
there are documented fixes for this issue ...
heres what I found
umfortunatly most of my pics have disappeared from servimg
misfire help 2013-016
https://www.k100-forum.com/t1833p550-85-rt-resto-my-attempt-hey-im-not-into-making-a-show-bike#71318
5Back to top Go down   misfire help Empty Re: misfire help Fri Mar 14, 2014 12:48 am
Check that the 4 pin connector on the sender is actually connecting properly. The female part of the plug opens up a bit and can cause intermittent connection.
The mistake many people make is to check for continuity of the wires from each side of the plug and not the actual connection of the plug itself.
They only need to open up 0.1mm and you have problems. I ended up replacing mine with a 4 pin spade terminal connector from an auto shop and no more problems.
6Back to top Go down   misfire help Empty Re: misfire help Fri Mar 14, 2014 5:25 am
good point rick
some folks head directly for the major item  before testing the interconnects ....and proving them reliable  before continuing ....gosh we see this all the time
7Back to top Go down   misfire help Empty Re: misfire help Sat Mar 15, 2014 5:34 pm
ReneZ
ReneZ
Making sure all plugs are properly seated might help as well., Often people have issues and then find out the computer plug was not properly seated. This is of course assuming that all connectors are clean ?? :-)
Rene
BMW K100 - 1985 (0030029) Scotland misfire help Rain
8Back to top Go down   misfire help Empty Re: misfire help Sat Mar 15, 2014 6:27 pm
Make sure your spark plug leads are on securely. They shouldn't wiggle at all.
9Back to top Go down   misfire help Empty Re: misfire help Sat Mar 15, 2014 6:37 pm
ReneZ
ReneZ
As Duck says, and make sure you have the bobbins on your spark plugs.
Rene
10Back to top Go down   misfire help Empty Re: misfire help Sat Mar 15, 2014 8:03 pm
japuentes
japuentes
Hi there, misfiring is usually related to timing, I would check static advance, advance over the rpm range, hall sensors and connectors.
Best regards
JAP
misfire help 2854237993 1988 K100RS SE/ABS
