1Back to top Go down   Cloudy windscreen Empty Cloudy windscreen Fri May 02, 2014 12:03 am
Hi all,
My newly acquired '85 K100RT has a very cloudy (orange/brown) colour on the screen. Not a riding problem as I look over it, but it would sure look nicer if it were clear.
Has anyone tried the kits they sell to fix cloudy headlight lenses for a screen?
Any other suggestions apart from a new one?
Thanks,
2Back to top Go down   Cloudy windscreen Empty Cloudy windscreen Fri May 02, 2014 12:16 am
All I know Bill, is do not cheat and use an electric buffing wheel.
I think it's has to be a hand job so to speak, with varying grades of paste. I was having success with 1200grit wet.dry and Autosol and decided to turn the buffer loose. Cooked the screen properly. It was then that I decided I didn't like it anyway. There is a thread somewhere with photo's, can't find it just now. It is  a slow progressively finer task. (toothpaste, talc etc). Someone will find it for you.
3Back to top Go down   Cloudy windscreen Empty Re: Cloudy windscreen Fri May 02, 2014 12:18 am
The miracle in a bottle is snake oil and really good if you are selling, it only lasts about a month.
I have used Brasso with reasonable results and I think Meguires do a polish for that sort of plastic.
If you use a power polisher it needs to turn slowly as a fast one like you use to buff paint on cars will burn the plastic.
I gave Charlie99 a very yellow screen and he managed to get it looking good, not perfectly clear but shiny and almost no yellow so he should know.
4Back to top Go down   Cloudy windscreen Empty Re: Cloudy windscreen Fri May 02, 2014 12:34 am
Save your elbow, buy a new one.  Get black like all the later RSs had.  Much lower maintenance.
JMHO.
5Back to top Go down   Cloudy windscreen Empty Re: Cloudy windscreen Fri May 02, 2014 12:38 am
Dale S
Dale S
I have done the screen on my 90 LT
Starting with 800 wet & dry paper, soapy water, going to 1000grit, then 1500grit. Then a good rub (by hand) with Maguires Plastic polishing compound, and finally a wax.
It was pretty scary looking until the polishing stage, then it looked great! Very Happy
I gained enough confidence to do the headlights on my 540i.
Just be careful, take your time, and sand in long straight lines, not circles.
1990 BMW K100LT
 2003 BMW 540i
 1998 Ford f-150
6Back to top Go down   Cloudy windscreen Empty Re: Cloudy windscreen Fri May 02, 2014 3:19 am
I used a P2500 grade wet and dry on the car headlights, used very wet and gentlly, very effective, then polish.
7Back to top Go down   Cloudy windscreen Empty Re: Cloudy windscreen Fri May 02, 2014 4:18 am
Bigsax
Bigsax
I just painted my RS screen black. Paint it from the inside, looks factory.
Cloudy windscreen Brick110
I stole this image, let me know if you want it back.
8Back to top Go down   Cloudy windscreen Empty Re: Cloudy windscreen Fri May 02, 2014 5:31 am
RicK G wrote:The miracle in a bottle is snake oil and really good if you are selling, it only lasts about a month.
yep still have it on rick ...thanks mate !
(besides some cracks that appeared near the mounting holes ...due to an enthusiastic  petrol over spray which hit the screen on a hot day ...don't know the science behind that ...sheesh )
the brasso worked well ..followed by maguires "plastix "
periodic polishing with ricks magic snake oil "automax" off ebay  seems to keep it in good condition
the screens I have seen (all old ones ) have slight imperfections throughout the plastic layers ...bit like stretch marks .....erm ...well that's a likeness ...not a derogatory statement
I guess if I kept the old bird about the speed limit this would be reduced somewhat ....
but hey ...if the old girl can do it ...im only too pleased to let her head loose every now and then  Cloudy windscreen 502531
please remember this is the older "original " rt type of fairing screen ...rather than anything new ....
Cloudy windscreen 1503890_10200254883734962_189261584_n
hope that helps
9Back to top Go down   Cloudy windscreen Empty Re: Cloudy windscreen Fri May 02, 2014 5:53 am
Check this link for the procedure
CF
Cloudy windscreen Frog15Cloudy windscreen Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
10Back to top Go down   Cloudy windscreen Empty Re: Cloudy windscreen Fri May 02, 2014 12:48 pm
Kyle10
Kyle10
This is what I use, along with microfiber cloths.
Resurrected many a windshield and fairing part with it to showroom effect.
I like it, as I don't have to commit to using sandpaper, which scares the bejeezus outta me.
Cloudy windscreen Novus111
1985 K100rt 0052183
1983 Honda VF750 007713
11Back to top Go down   Cloudy windscreen Empty Re: Cloudy windscreen Thu Jun 19, 2014 4:55 am
rhyleyz
rhyleyz
I use Plexus. It cleans and polishes the winshield of my bike. It can also be used on helmets.
