1Back to top Go down   Opinions on which gauges to add Empty Opinions on which gauges to add Thu Aug 28, 2014 4:53 pm
K100Sprint
K100Sprint
Hi y'all,
I have been thinking about adding some VDO gauges to Max, and I wondered if anybody has an opinion to share regarding what they might have added themselves, or perhaps want to in the future. I like the idea of insetting the following—in a 2-per-side arrangement.
Left fairing:
top: water temp
bottom: volt meter
Right fairing:
top: oil pressure
bottom: oil temp
Thoughts? Questions? Sarcasm?
May the road rise to meet you ... and may gas prices drop substantially.
1985 K100 w/ Sprint fairing
Member BMWMOA #64178
Member GNBMWR #118
2Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Thu Aug 28, 2014 5:55 pm
ReneZ
ReneZ
I wouldn't be too worried about the oil temperature on a water cooled bike and the location for the sensor could end up in quite a discussion :-)
It's all doable. Voltage and water temp very easy (fit sensor in water pump, replacing the drain plug), for the oil pressure you can get a combined pressure sensor/switch (bit of a big thing) which would screw in the place where the pressure switch now sits.
If you list your bike in your signature it's a bit easier to respond.
Rene
BMW K100 - 1985 (0030029) Scotland Opinions on which gauges to add Rain
3Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Thu Aug 28, 2014 7:10 pm
Sarcasm?
On this site?
Voltmeter, water temperature, oil pressure. That'd do me.
4Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Fri Aug 29, 2014 4:00 pm
K100Sprint
K100Sprint
Cool guys, thanks for the replies and input. I think that instead of an oil temp gauge, I'll put an analog clock in ... especially since the factory digital unit is just a black smudge.
Wish those Fuel+ dealios were still on the market ...
Member GNBMWR #118
5Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Fri Aug 29, 2014 8:29 pm
brickrider
brickrider
Fuel+ gauge?  Oh, technology has moved well beyond that.  There's a bright young man in the S.F. Bay area who made a computer that gives the rider fuel consumption info among perhaps 10 other things.  It's priced very reasonably too.  I love the one on my K100RS! It was pretty easy to install and has proven dead reliable as well.
  The creator of that computer may well be on this forum too, I'm not sure, but I seem to recall a post from him some time back.
6Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Fri Aug 29, 2014 8:34 pm
I have four VDO gauges on my 94 RS:
Fuel
H20 Temp
Voltage
Ambient Air Temp (mostly for winter riding to tell if the temps can ice up the roads)
7Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Fri Aug 29, 2014 8:34 pm
Yep mine is going well but took some time to tune it to a K1100.
8Back to top Go down   Opinions on which gauges to add Empty Opinions on which gauges to add Sat Aug 30, 2014 12:11 pm
George R
Brickrider - Do you have any further information about the computer unit you mentioned above?
9Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Sat Aug 30, 2014 12:56 pm
K100Sprint
K100Sprint
George R wrote:Brickrider - Do you have any further information about the computer unit you mentioned above?
Yes, do tell ...
Member GNBMWR #118
10Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Sat Aug 30, 2014 7:25 pm
brickrider
brickrider
Inquiries should be directed to WMAX351, a member of this forum.
He's the creator; he's the expert.
11Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Sat Aug 30, 2014 10:23 pm
12Back to top Go down   Opinions on which gauges to add Empty Like to see Pic Fri Nov 07, 2014 9:52 am
Mark K Boy
Mark K Boy
duck wrote:I have four VDO gauges on my 94 RS:
Fuel
H20 Temp
Voltage
Mate , I want to add a oil pres plus a volt to my K1100RS 93/94.
Could you post a picture of where you put yours?
I have replaced the fuel and temp with VDO,
I see you can buy a mini mech oil gauge, VDO.... but I can not find a volt meter as yet.
Id like to see what you have done....
http://www.marksurman.com
13Back to top Go down   Opinions on which gauges to add Empty Gauges Fri Nov 07, 2014 12:10 pm
Gordon Smith
Gordon Smith
Marky, try a trip to a good boat chandlery. I needed 2 units myself temp and volts, got them both for half the price of Bmw,Both matched and made by Siemens and marine weatherproof.---Just a thought, Very Happy
14Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Tue Nov 18, 2014 5:45 am
Mark K Boy
Mark K Boy
Thanks Guys,
I got all my new Gauges now:-
Fuel
Temp
Oil Pressure (Electrical)
Volts,
I've worked out where to put them _ (I will post photos when done)
I've seen posts where a gentlemen added a oil pressure gauge (capillary). I noted where he took the line out of the block.....
I'm still looking to where to mount my sensor......
any ideas would be good.....
Thanks.
Mark Surman
Keep the shinny side up !
Opinions on which gauges to add Au-log12
15Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Tue Nov 18, 2014 6:42 am
marky .......to me an electrical sender is the wise choice
just a heads up to be careful .
the standard pressure sensor is on the output side of the pump ventricle ...at the bottom of the oil- water pump
you might see 2 sensors down there
one for the temp sender to additional gauges (not the ecu )  the other to the warning lamp in the instruments  ,,,,oil
16Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Tue Nov 18, 2014 11:00 pm
Mark K Boy
Mark K Boy
charlie99 wrote:marky .......to me an electrical sender is the wise choice
Thanks Mate,
I'm thinking a branch type set up with the Oil Pressure warning lamp sensor.
Im surprised to have not found this on the form somewhere.... I may not be looking in the right place......
Im also surprised not to have heard back from other members on the cooling fan mod I did (I posted it in the wrong place maybe) - It works super well.
Maybe its just a hot sunny Australia thing - we can not do traffic...... (I can now!)
Mark Surman
17Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Tue Nov 18, 2014 11:08 pm
"I'm also surprised not to have heard back from other members on the cooling fan mod I did".
Can you post a link to that please Mark and I am interested in where a pressure line was tapped in for the gauge as I don't like being without an Oil Pressure Gauge and also didn't like having a great big sender hanging off the pump and being very vulnerable.
18Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Tue Nov 18, 2014 11:13 pm
Mark K Boy
Mark K Boy
RicK G wrote:"I'm also surprised not to have heard back from other members on the cooling fan mod I did".
Cooling fan Mod,
you will have to scrol down..... you will see my post, pictures etc......
https://www.k100-forum.com/t4903-replacing-the-cooling-fan
Mark Surman
19Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Tue Nov 18, 2014 11:26 pm
I just bought a 9 inch fan and will move the radiator forward about 20mm to accommodate and it drags a real heap of air. See how it goes on the chookie, probably couldn't use it on a regular LT/RS due to clearance on the frame.
20Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Tue Nov 18, 2014 11:32 pm
Mark K Boy
Mark K Boy
Good Luck!
Mark Surman
21Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Wed Nov 19, 2014 3:03 am
even the 7,5 inch quoted as 7 inch   drags a heap more air rick but there are differences in suppliers and design and throughput
good luck
22Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Mon Dec 15, 2014 9:12 pm
Mark K Boy
Mark K Boy
RicK G wrote:I just bought a 9 inch fan and will move the radiator forward about 20mm to accommodate and it drags a real heap of air. See how it goes on the chookie, probably couldn't use it on a regular LT/RS due to clearance on the frame.
https://www.k100-forum.com/t1751-k100-cooling-fan-problem#108416
The above Mod works beautifully.
I can do traffic now...... Opinions on which gauges to add Icon_biggrin
Enlarge this image
Opinions on which gauges to add 73f1b74c3ce549befb0de19cbcb25d0e
Mark Surman
23Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Mon Dec 15, 2014 9:59 pm
Mark K Boy
Mark K Boy
Opinions on which gauges to add D13e55d6ebbb499e0c8e2687f9f71acb
Opinions on which gauges to add 410c381fb37d639220bc63ff542de443
Opinions on which gauges to add 6ada168c71f6857452fe34f2dad507a5
Mark Surman
24Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Mon Dec 15, 2014 10:51 pm
Be made
Be made
blaKey wrote:Sarcasm?
On this site?
And don't forget the tyre pressure sensors too . . . Opinions on which gauges to add 44271
25Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Mon Dec 15, 2014 10:56 pm
Mark K Boy
Mark K Boy
On this site?
That would be ME looking over my right shoulder when my girlfriend gets on..........
Mark Surman
26Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Fri Dec 19, 2014 7:57 am
Mark K Boy
Mark K Boy
End result.......
Opinions on which gauges to add 7beef37015ddb68d4bf696bdfb2e4f40
Opinions on which gauges to add 3b5f83a5439bb7d451a1f3f9199fa515
Mark Surman
27Back to top Go down   Opinions on which gauges to add Empty Re: Opinions on which gauges to add Sun Jun 14, 2015 1:27 am
Mark K Boy
Mark K Boy
Be aware - If you replace the fuel gauge with a newer VDO as above you will have to pull the fuel gauge sensor out of the tank and turn the rheostat strip around the opposite Direction as to make good the direction of the needle in the new gauge........
This needs to be done with care and the varnish that is covering the fine wire needs to be removed in order to make contact with the pickup.....
Sand off the varnish off with fine wet and dry paper moving hand in the direction that the pickup will follow.
Then comes the calibration..... bend and test...... bend and test....... bend and test    (the float)
If you have any questions please post......
Opinions on which gauges to add 4c2a79edb0e1936527a57968882a8890
Mark Surman
