1Back to top Go down   New member from California Empty New member from California Mon Oct 13, 2014 9:57 am
Dstoner25
Dstoner25
Hey guys,
So I bought a bmw k100 and I'm not sure what year it is. I'm thinking it's a 85-86 but not sure. The last time it was registered was in 2007 so was curious is it had back fees, does anyone know if I get another frame with a title will my motor effect it. Just looking for advice reason why I joined.
2Back to top Go down   New member from California Empty Re: New member from California Mon Oct 13, 2014 10:10 am
Welcome Dstoner,
If you follow the advice many give, to put details of your bike including frame number in your signature or even in a post, there are experts here who can look up its build date and even which market it was built for.
Not sure about the rest (back fees and title), as there are many things different between California and Oz. Surely someone on the forum can help with that too.
Stick with the forum and you will likely find the answer to almost any question you have about a K.
Cheers,
3Back to top Go down   New member from California Empty Re: New member from California Mon Oct 13, 2014 8:12 pm
Hi Dstoner25
Welcome to the forum.
You'll find the compliance plate rivited to the rear R/H side of the frame, just below the side cover.
The build date (MM/YY) and VIN number will be stamped on it. Also the VIN number will be stamperd on the frame just in front.
There should not be any back fees as when rego runs out the vehicle becomes unregistered. In Australia once the vehicle is unregistered for a specified length of time it then needs to undergo a more detailed roadworthy vehicle inspection before it can be registered again.
What you'll need to check though is whether there is any claim on the title of the bike. You should be able to do that at the registry office or what ever you call it in the US. Do that before you spend any money on it.
If its been sitting around for 7 years, there will be a few things that will probably need replacing before getting it on the road. There's lots of info on the portal page (L/H tab at the top).
Good luck
 New member from California Austra12    Fuel:  95 Octane
4Back to top Go down   New member from California Empty Re: New member from California Tue Oct 14, 2014 12:51 am
k-rider
k-rider
Welcome
k-rider
5Back to top Go down   New member from California Empty Re: New member from California Tue Oct 14, 2014 1:24 am
Dstoner25
Dstoner25
Thanks guys I got the bike for free ran a compression check got 150-160 on all 4 cylinders. I ran into a electrical issue found out the ignition switch wasn't putting power to the electrical box. I still have an issue with the neutral light not on. I'll be posting in the forums because I need a gas tank and a fuel pump because I don't have one. I usually work on vintage Hondas so this is new for me.
6Back to top Go down   New member from California Empty Re: New member from California Tue Oct 14, 2014 1:59 am
A list of Fuel pumps that are the same, plus many US cars
HOLDEN Commodore VK EFI, VL turbo and non turbo, VN onwards V6 and V8 sedan wagon statesman
HOLDEN Camira JD JE Astra Calibra
FORD Falcon XE XF EFI
FERRARI 412i Coupe
NISSAN Skyline Pintara Pulsar Bluebird
ALFA ROMEO 33 Alfetta 75 90 GTV Spider
BMW M3 E30 M5 E28 318i 320i 323i 325e 325i 520i 525e 528i 535i 633Csi 635Csi 733i
CITROEN
FIAT Argenta Brava Regata Strada Ritmo X19
JAGUAR XJ6 XJs Sovereign
LANCIA Beta Delta Gamma Prisma Trevi Y10 Turbo
LOTUS Esprit Turbo
MASERATI Bi Turbo
MERCEDES-BENZ
MG Metro Turbo Maestro Montego
MITSUBISHI Colt Turbo Lancer
OPEL Ascona Corse Kadett Manta Monza Omega Rekord Vectra
PEUGEOT 205 309GTi 405 505
RENAULT R5 Turbo R11 Turbo R18 Turbo R19 R21 Turbo R25 Turbo Espace Quadra Fuego
ROVER SD1 Vitesse 3500 Vanden Plas RANGE ROVER LAND ROVER 3.5 & 3.9 EFI
SEAT Ibiza Malaga
VOLKSWAGEN Transporter Caravelle
As for tanks if yours has a leak below the pump most tanks are the same. I have had great success with this
http://www.permatex.com/products/product-categories/specialized-maintenance-repair/professional-repair-systems/permatex-fuel-tank-repair-kit-detail
7Back to top Go down   New member from California Empty Pump costs Tue Oct 14, 2014 4:24 am
WandererK1
WandererK1
RicK,
What can a fuel pump be sourced for $$$ wise, and are they the same on the K1 an later bikes...
Cheers Jeremy
8Back to top Go down   New member from California Empty Re: New member from California Tue Oct 14, 2014 5:05 am
AFAIK the K1 is the same as the rest.
Price wise this is what I use in the K1100. http://www.ebay.com.au/itm/1-x-Brand-New-Fuel-Pump-Ford-Falcon-Fairmont-Fairlane-EA-EB-ED-EF-EL-Sedan-/371104302128?pt=AU_Car_Parts_Accessories&hash=item56678a4430 the dia is smaller but nothing a couple of big zip ties wont fix.
The ones in the above post are a match and 52mm dia but smaller pumps are just as good providing they have the volume capacity and pressure.
There are a hell of a lot of pumps that will work with the LJetronic as the only requirements are volume and pressure.
The only thing special about a BMW pump is that it has BMW on the box and a super duper price.
9Back to top Go down   New member from California Empty Re: New member from California Tue Oct 14, 2014 5:27 am
RicK G wrote:AFAIK the K1 is the same as the rest.
Some things best to buy BMW, but fuel pump is not one of them. A lot of BMW parts seem common to other motors.
10Back to top Go down   New member from California Empty Re: New member from California Tue Oct 14, 2014 9:46 am
Dstoner25
Dstoner25
Anyone know where to get a good gas tank?
11Back to top Go down   New member from California Empty Re: New member from California Tue Oct 14, 2014 3:49 pm
Take care to get the right tank for your bike.
Main variables are the mountings and the fuel level sensor.
The different fuel level devices require different wiring looms and different circuits in the speedo console.
Also I think K75 tanks are a different shape although they look similar.
Just something of which to be aware.
12Back to top Go down   New member from California Empty Re: New member from California Tue Oct 14, 2014 4:29 pm
mtndv8
mtndv8
Dstoner25 wrote:Anyone know where to get a good gas tank?
Been watching this one...
...dont blink. Ending in a matter of hours.
http://www.ebay.com/itm/361074407428?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT#ht_5534wt_927
As someone else mentioned in another thread, shame to see that bike parted out. That said, I've got a bid or two in on some of it's bits.
Last edited by mtndv8 on Tue Oct 14, 2014 4:31 pm; edited 1 time in total (Reason for editing : ...forgot to say WELCOME!!)
