1Back to top Go down   Odo gears Empty Odo gears Thu Feb 05, 2015 7:01 pm
Wanted....2 cogs that go in the odo/trip meter part of the instruments......metric...km per hour speedo.
I replaced a whole set in one bike last year and this summer in mild temperature...32 C the gears are "gluing" themselves together. Has any one got the following and are willing to part with them...
The two upper most...closest to the single primary gear.....16/44 teeth and 34/40 teeth.
The bloke I bought the set from prefers to sell sets only and I found out that the other two cogs...closest to the body of the speedo have no wear at all. It seems a waste to get a set.
2Back to top Go down   Odo gears Empty Re: Odo gears Thu Feb 05, 2015 10:11 pm
Found these, are they any good to you? One on left is no good missing a tooth.Odo gears 100_0713
K100 RS
K100RS with 1100 motor Premier sidecar
K100 RT KRAUSER FAIRING
R1200GS
650 Vstrom
3Back to top Go down   Odo gears Empty Re: Odo gears Thu Feb 05, 2015 10:20 pm
Hopefully this guy can help you out. He sells them individually. Hope it's what you need.
Odometergears.com
 Odo gears Austra12    Fuel:  95 Octane
4Back to top Go down   Odo gears Empty Re: Odo gears Fri Feb 06, 2015 3:47 am
that seems to be the most common failure waz
did rt  get a couple of gears one time from a local supplier ....Penrith agent for odo gears seems to ring a bell ...just from memory
5Back to top Go down   Odo gears Empty Re: Odo gears Fri Feb 06, 2015 4:28 am
Waz...the one in the middle could work. I have found the smaller ones closer to the speedo tend not to be affected by heat. I have got onto a bloke called Richard who sells the cogs and he will sell them individually at $25 each plus $9 to send. I suppose that isnt too bad for about 30 years of use.
Should have mentioned before...the cogs I replaced last year are fine..in red bike...now the same type of problem in the orange bike.
6Back to top Go down   Odo gears Empty Re: Odo gears Fri Feb 06, 2015 5:30 am
PM me your postal address and I will send these to you
K100 RS
R1200GS
650 Vstrom
