1Back to top Go down   Odometer broken Empty Odometer broken Fri Feb 13, 2015 8:49 pm
73MOH
73MOH
Gday All,
I've found the culprit, but where am I going to find a replacement?
Odometer broken 2015-02-14%2010.38.05_zpsse9d8vqj
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
2Back to top Go down   Odometer broken Empty Re: Odometer broken Fri Feb 13, 2015 8:54 pm
They are available Paul have a search here and the www for speedo gears. They often are only available in sets but it probably not a bad idea to replace all as they are the same age as the busted gear. This is one place in Oz but there are others http://www.repairsonly.com.au/index.html
3Back to top Go down   Odometer broken Empty Re: Odometer broken Fri Feb 13, 2015 9:10 pm
73MOH
73MOH
Thanks Rick... I've sent him an enquiry..... The broken gear appears to be made of rubber, when all the others appear plastic.
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
4Back to top Go down   Odometer broken Empty Re: Odometer broken Fri Feb 13, 2015 11:38 pm
This guy has sets of gears or you can buy them individually.
http://www.odometergears.com/products/BMW/R+%26+K+Motorcycles/42
I've not bought anything from him.
Good luck
 Odometer broken Austra12    Fuel:  95 Octane
5Back to top Go down   Odometer broken Empty Re: Odometer broken Sat Feb 14, 2015 2:16 am
The broken gear can be replaced with a gear from Jaycar...total cost about $8. You also get some other gears in the pack. The other gears you have to get from other sources and they are about $25 each plus $9 to send to you. The gears start out as hard "plastic" feeling cogs and with time and heat become almost candle wax. Bend your rubber gear and it will break. That main small gear is on a bush and the replacement has no bush, and the Jaycar replacement also needs to to trimmed as it is too wide. Check the holes on either end of the gear...one is narrower than the other....push the bush on starting with the wider side. The old bush can be taken off with side cutters, but don't cut across the bush, rather along the length...squeeze the cutters and the bush will come off.
Good luck.
6Back to top Go down   Odometer broken Empty Re: Odometer broken Sat Feb 14, 2015 7:24 am
WoodyAUK75
WoodyAUK75
I searched this recently and there was a post saying The BM Shop would do the job for $200, so they should have the bits. I am looking at this repair myself (When winter comes around) I am going to try Otto instruments as well.
7Back to top Go down   Odometer broken Empty Re: Odometer broken Sat Feb 14, 2015 9:30 am
That was me and my speedo.
He won't sell the bits! No way, no how.
Otto is the guy to go to, I believe.
8Back to top Go down   Odometer broken Empty Re: Odometer broken Sat Feb 14, 2015 9:32 am
Paul, I've PM'd you.
9Back to top Go down   Odometer broken Empty Re: Odometer broken Sat Feb 14, 2015 10:08 am
Otto's got all of the gear choices, but I had to go there with my old cogs and select the colours/sizes I needed. As they're in the business of repairing instruments they appeared slightly reluctant to sell me only individual pieces, stating to me something like "Mate, there's a whole lot of other bits in there that need replacing as well" but as I had the cogs I needed in hand, and a pretty woman with me, they relented.
10Back to top Go down   Odometer broken Empty Re: Odometer broken Mon Feb 16, 2015 5:13 pm
This seems to be a problem in hot climates........we don't get many broken gears here. Odometer broken 178468
I once had some nylon cable ties that had become brittle; each time I tried to pull them tight, they broke. An industrial chemist friend said that nylon has a water content and it can dry out. He suggested soaking the ties in water for a couple of days and hey ho, they're still supple after a couple of years.
Now I'm not suggesting that you soak your speedo in a bucket of water....... Odometer broken 8157
11Back to top Go down   Odometer broken Empty Re: Odometer broken Mon Feb 16, 2015 5:19 pm
I have been informed that the lubricant that was applied to the cogs at the factory was great for cooler conditions, however given heat and time the lubricant became acidic and helped break down the plastic. The bloke who supplied my gears said that Mercs and BMW cars the era of our bikes have similar problems, except to get the speedos out of cars is far more complicated....and expensive.
12Back to top Go down   Odometer broken Empty Re: Odometer broken Mon Feb 16, 2015 6:44 pm
sidecar paul wrote:This seems to be a problem in hot climates........we don't get many broken gears here. Odometer broken 178468
very true paul
we had to maintain  some electronic perimeter systems involving cable ties every 8 inches (200mm) along a fence in the sun et all   after a dry spell was the best time to remove them for replacement ....they would just sheer off without much energy ....after a rain event they were quite obstinate to cut even .
13Back to top Go down   Odometer broken Empty Re: Odometer broken Mon Feb 16, 2015 10:13 pm
Mark K Boy
Mark K Boy
Odometer broken 09f82ede4a5af3b5473225d86b0d495a
73MOH wrote:Gday All,
Mate - Im in Bris - I've have some spare new ones after doing same to a couple of bikes.....
You are welcome to them....
Mark Surman
Keep the shinny side up !
Odometer broken Au-log12
http://www.marksurman.com
14Back to top Go down   Odometer broken Empty Re: Odometer broken Wed Feb 25, 2015 4:45 pm
73MOH
73MOH
Thanks everyone for the offers and advice..... Blakey was kind enough to send me the gear I needed, and it worked a treat.
Blakey, here is our lotto ticket for Saturday night (50/50).... and thank you very much.
Odometer broken 2015-02-25%2018.05.10_zpstxqxpmib
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
15Back to top Go down   Odometer broken Empty Re: Odometer broken Thu Feb 26, 2015 3:22 am
No problems Paul...anytime.
Don't lose the bloody ticket! Ya just never know! Very Happy
16Back to top Go down   Odometer broken Empty Re: Odometer broken Thu Feb 26, 2015 3:29 am
onya blakey
geez....yet another "angel of solving dilemmas"  this guy is awesome
thanks for your terrific support mate
happy riding paul
17Back to top Go down   Odometer broken Empty Re: Odometer broken Thu Feb 26, 2015 3:48 am
My Dad always said "what goes around, comes around" and I'm a big believer of that.
If I have a spare and I'm not using it, I'll pass it on.
