1 A bit of a tidy up. Wed Mar 18, 2015 10:25 am
To paraphrase Michael Caine in the Italian Job:-
You were only supposed to change the bl**dy front tyre!
Over the past couple of years I've been collecting and repainting parts with the intention of tidying up my solo.
I needed a new front BT45 so I had one fitted to my newly painted (at enormous expense) wheel. I was planning the refurb for sometime in May, when my wife will be in America. I can then move my steam engine, bicycle and a few other big items out of my workshop and into the lounge, thereby freeing up some space to work on the solo indoors.
So, I took the old wheel out and then thought 'I might as well change the fork legs for the re-painted ones'. Well, without the front wheel in place I could feel the head bearings, what a shocker, rough as old boots!
Then the fork yokes came off, but not without a fight. The top nut just wouldn't move, even with the chamfer on my 30mm socket turned off to get a good purchase on the nut and my impact wrench with a big hammer. I resorted to carefully cutting through the nut to release the tension.
Fortunately I had already made a new stainless top nut.
Once I had got to the head bearing, I did the finger nail check on the inner race and, to my surprise, it was smooth as silk. The roughness was just hardened grease, so a good washing of the bearings and re-greasing solved that little hick-up.
Having had the bearing adjustment ring off, I'm trying a 'solo' version of my sidecar steering damper. Instead of using 'O' ring rubber, I'm trying 5mm expanded neoprene. As well as giving a bit of friction damping, it will also act as a seal, keeping water out of the bearing.
So far it feels good, but I'll have to wait until a road test to decide if it's really worth doing.
Newly painted handlebars, levers and housings, top yoke, new bar rubbers and fairing boots, new heated grips and brake lines and a lot more to go yet.
To be continued.......
