1Back to top Go down   The deeper you dig........ Empty The deeper you dig........ Thu Aug 06, 2015 4:34 pm
On Monday I decided to replace the handlebars, levers and top yoke on the outfit with some newly painted ones that I've had lying around for a year or more.
Oh, while the old top yoke is off, I might as well replace the split rubber boots between the forks and fairing.
 Of course, that means removing the front wheel, mudguard, brakes, fork legs and all sorts of bits and pieces that get in the way.
With the forks dismantled, I suppose they could do with re-painting. (These are Wasp forks, not the standard BMW forks.)
All day Wednesday was spent manually scraping off all the powder coating. Even the areas that looked good had still suffered from the creeping rust sickness that seems common with powder coating and previous smooth areas had an 'orange peel' surface caused by rust under the coating. All the bits have now had two coats of primer and three coats of Plasti-kote; now hanging in the workshop to harden while I go off camping for the weekend on the Vincent.
Ah, now the front end is out of the way, I could have a look to see why the fan hasn't been working lately. No fan isn't too much of a problem in the UK, but it does need sorting. So, off with the radiator to find a big blob of melted plastic where a fan motor brush used to be.
The deeper you dig........ Sam_1214
I guess that 29 year old radiator hoses are well past their sell-by date, so a new set along with a new fan are on order from 'bins.
Now, what's this, with all this access I can see a split in No1 throttle body rubber. Ah, that would explain the odd behaviour of my mercury gauge on No1 cylinder when setting the by-pass screws.
 What will I find next? I wonder, will I end up as far as the output shaft?.......I could put the 12 riveter in!!!
It's a good job I've got the solo K and the Vincent to keep me sane.  The deeper you dig........ 8157
2Back to top Go down   The deeper you dig........ Empty Re: The deeper you dig........ Thu Aug 06, 2015 8:45 pm
good onya paul ...its amazing what one finds if you go looking
good luck with it all
3Back to top Go down   The deeper you dig........ Empty Re: The deeper you dig........ Fri Aug 07, 2015 11:29 am
Be careful painting BMW handlebars as the tolerances are very tight and the added thickness may make it hard to get the throttle and clutch perches back on.
4Back to top Go down   The deeper you dig........ Empty Re: The deeper you dig........ Fri Aug 07, 2015 12:26 pm
Brad-Man
Brad-Man
I bought a duplicate of my first street bike (Yamaha RD350) with the intention of just cleaning it up and having fun on it around town.
So many things wrong it has become a total ground-up and enhancement project.
Currently adding 2 LED Brake/Taillights, 7" round HID headlight and 2 LED driving light to my '85 K100.
These combined with the DayGlo Yellow jacket and DayGlo Orange helmets will do as much as can be done for conspicuity.
I don't care if I look like a clown - I've been hit before...
The deeper you dig........ Usa-lo10
5Back to top Go down   The deeper you dig........ Empty Re: The deeper you dig........ Wed Aug 19, 2015 5:20 pm
Well, it's all back together and these are all the bits left over. affraid
The deeper you dig........ Sam_1220
All those fixings have now been replaced with stainless and I surprise myself how many non-stainless fixings I still find.
While it's all very nice to know that you've got new throttle body rubbers, throttle cable, radiator hoses, fan, shiny black handlebars, etc, they are all parts that you can't see.  Sad
However, the re-painted forks, top yoke, new floating discs and new white brake lines are all on show.  cheers
The deeper you dig........ Sam_1221
I even fitted the handlebar risers that I made some years ago. I've never found the standard RS bars a problem, but, as many of you seem to fit risers, I thought I would give them a try; I can always go back to standard if I don't notice any improvement.
The deeper you dig........ Sam_1222
It's a good job a K is worth all the effort.  roundel
6Back to top Go down   The deeper you dig........ Empty Re: The deeper you dig........ Wed Aug 19, 2015 6:23 pm
A fantastic job Paul and the timescale is very impressive and not a cable tie in sight.
But you didn't get as far as the rear wheel......88KE will be disappointed for sure.
I just hope you never get a puncture.....
7Back to top Go down   The deeper you dig........ Empty Re: The deeper you dig........ Wed Aug 19, 2015 7:29 pm
92KK 84WW Olaf wrote:A fantastic job Paul and the timescale is very impressive and not a cable tie in sight.
Dissapointed....I'm positively depressed I managed to start polishing one header tonight and was impressing myself 'till I saw THAT brilliant front end! I like the white brake lines. It's difficult to know where to stop once you start stripping!
The deeper you dig........ Ir-log1188....May contain nuts!The deeper you dig........ Ir-log11
K75RTP - 1994
8Back to top Go down   The deeper you dig........ Empty Re: The deeper you dig........ Thu Aug 20, 2015 5:09 am
stunning job paul
wow !!
Will, don't give up mate ...we know you can do great stuff
9Back to top Go down   The deeper you dig........ Empty Re: The deeper you dig........ Thu Aug 20, 2015 4:30 pm
Don't panic Will, that front end will soon get dirty again.  Sad
The only alternative is not to use it..............and that's never going to happen.  The deeper you dig........ 723598
