1Back to top Go down   Coolant ? Empty Coolant ? Fri Oct 31, 2014 6:10 pm
paulespo
paulespo
Has anyone been using any other brand of coolant other than BMW high priced rip off brand?
BMW don't make coolant and charges a hefty price to put there name on some. I know of people who use Prestone coolant and had no problems.
2Back to top Go down   Coolant ? Empty Re: Coolant ? Fri Oct 31, 2014 8:34 pm
I've been using the local no-name brand from the wee shop up the road and never had any problems. We stuff it in the car too. Ethylene glycol is just ethylene glycol, however you package it. Just be sure to use distilled water to stop clogging up the system with limestone/peat/add your local groundwater contaminant here.
3Back to top Go down   Coolant ? Empty Re: Coolant ? Fri Oct 31, 2014 9:02 pm
I use the green Nulon, that is a brand name, but any of the brand name are good.
4Back to top Go down   Coolant ? Empty Re: Coolant ? Mon Nov 03, 2014 1:44 pm
Kyle10
Kyle10
I use Engine Ice
A bit pricey but it addressed what I was looking for, namely cooler idling/city riding. Markedly effective.
1985 K100rt 0052183
1983 Honda VF750 007713
5Back to top Go down   Coolant ? Empty Re: Coolant ? Mon Nov 03, 2014 5:55 pm
Be made
Be made
I have been using the standard local antifreeze, branded Partmaster (an auto parts supply chain). No problems.
Remember that what these K bike motors are is essentially a shrunken version of a car engine flipped on it's side and chucked in to a motorcycle frame with not a lot of difference mechanically as far as cooling requirements are concerned
In fact they probably run a fair bit cooler than a car version with the exposure to the rushing air and a lot less weight to push around than a car
I don't over think things as far as this model of bike goes
I use normal antifreeze, Ryco Z418 oil filters instead of the beema expensive ones and a higher detergent diesel engine oil just as a precaution to perhaps slow down the sludge buildup that affects the starter clutch
6Back to top Go down   Coolant ? Empty Re: Coolant ? Mon Oct 03, 2016 9:44 am
kryder
kryder
Dai wrote:I've been using the local no-name brand from the wee shop up the road and never had any problems. We stuff it in the car too. Ethylene glycol is just ethylene glycol, however you package it. Just be sure to use distilled water to stop clogging up the system with limestone/peat/add your local groundwater contaminant here.
 Yep, any brand or generic will do the trick. I buy 50/50 and call it good. I could care less about the brand on the container. I think I last purchased O'Reilly's auto store self labeled anti freeze here in the states. It is a little less expensive and probably made by Prestone or some other major brand.
Last edited by kryder on Mon Oct 03, 2016 9:45 am; edited 1 time in total (Reason for editing : Typo)
7Back to top Go down   Coolant ? Empty Re: Coolant ? Mon Oct 03, 2016 9:58 am
BobT
BobT
The best anti freeze is pure water. Add anything else and it becomes less thermally efficient. You need to use anti freeze because it is also corrosion inhibitor and antifreeze. The coolant does not give a monkeys whether it is in a car or a bike, but the K engine has nothing to do with any car engine.
Better to let the engine run at the correct operating temperature so anyone who tells you that a coolant can cool better than water is talking rubbish. Why would you want it to run cooler, you will only damage the engine if you don't get it up to operating temperature every time you ride it.
