1 New member with a question Mon May 15, 2017 4:28 am
KurtHeide
So, Before I ask for your advise, let the new guy introduce himself.
I'm New Jersey born and raised, spent 4 years living in New Hampshire and Boston. Living in Florida for the past 25 years.
Been riding bikes since I was 12 and I'm 59 now! Bike history: Honda Mini Trail Z50, ct70, Sl70, dt185, sl175, CB350, CB550K, Katana 600, VFR750F, 2 Harley Davidsons (currently a Road King) and now my first BMW: 1991 k100rs 16 valve. I still have the VFR too
The BMW is a garage find with 7900 miles on the clock. Replaced all the seals, tires, brakes lines, rear rotor (it was warped) and master cylinder. Rear tire spins freely while bike is on its center stand with only a negligible audible intermittent rub on the rear brakes rotor. Calipers bled clean and are not stuck. Brake pedal functions fine with about 2 inches of play before engaging the rear brake. I do not ride with my foot on the brake pedal. According to the shop manual, ABS is functioning correctly as well
Here's my question: Is it normal for the rear brake rotor to be hot to the touch after normal cruising around town? If not what could I have missed that would be causing the issue?
Any thoughts on the matter would be appreciated.
Kurt
Kurt
