1Back to top Go down   New member from Portland oregon Empty New member from Portland oregon Thu Jun 29, 2017 4:28 am
Semlisun
Semlisun
Hello everyone, my name is Simon and a recently picked up a 1988 K100rs. It has 81,000 on the odometer and what looks to be a small oil leak from the back of the engine. Might be a clutch boot or rear main seal.
The only experience I have so far is I rebuilt a 1978 Honda cb750 and but I really like the look of the k100 and when the time was right was able to pick one up for a great deal.
I am planning to replace all the rubber, clutch, rear main seal and all the oils and fluids.
With this I will also do the spline lube.
Any advice will be greatly appreciated.
2Back to top Go down   New member from Portland oregon Empty Re: New member from Portland oregon Thu Jun 29, 2017 8:23 am
WelKome from another Pacific Northwet member.
I wouldn't replace the rear main seal unless it's leaking. A common source for oil leaks at the rear of the engine is the clutch nut O-ring. Once you take the transmission off to access the clutch you will know what the cause of your oil leak is.
3Back to top Go down   New member from Portland oregon Empty Re: New member from Portland oregon Thu Jun 29, 2017 3:33 pm
Semlisun
Semlisun
Thank you!
That's exactly what I was going to do. Just assess it when I get into it.
