1Back to top Go down   DIY Starter Switch Empty DIY Starter Switch Sat Sep 23, 2017 1:00 pm
uhoh7
uhoh7
If the bike will push start and runs fine, and the starter is clean and responds to a jump, but either OEM switch/rely is not working or unwanted, then a new starter switch is pretty easy as you see.
There is a good spot on the coil cover, and last shot shows cable routing. Basically all you need: high amp switch, heavy gauge wire, two short lengths. Drill a hole in coil cover about 20mm inboard from inner edge, centered between mounts. Route one cable to starter and carefully attach other end to battery. Mind your connections are not going to pop loose.
DIY Starter Switch 37265289321_2498c31fb5_b
Starter switch by unoh7, on Flickr
DIY Starter Switch 36555486304_7772ae23ec_b
DIY Starter Switch 37218476406_d7cb0e3872_bStarter switch by unoh7, on Flickr
DIY Starter Switch 36555487014_91e7230dd2_b
Once I learned the oem switch just allows a direct short unfused feed from battery, then I figured a work around should be easy. The button is big and not going to be pressed by accident. Yes it will turn the bike over with key off. Smile
DIY Starter Switch 37010251610_ce0fd3425d_b
Switch by unoh7, on Flickr
Don't get me wrong: I would prefer the OEM method working, on my own bike. But this works fine, it seems.
2Back to top Go down   DIY Starter Switch Empty Re: DIY Starter Switch Sat Sep 23, 2017 1:42 pm
Chocolate
Chocolate
Hello!
Nice solution.
Thanks for sharing.
3Back to top Go down   DIY Starter Switch Empty Re: DIY Starter Switch Sat Sep 23, 2017 1:50 pm
Use tinned #12 or #10 AWG stranded wire and crimp-on ring terminals.  I promise that you will regret wiring it the way you did in a year or so.
4Back to top Go down   DIY Starter Switch Empty Re: DIY Starter Switch Sat Sep 23, 2017 2:49 pm
Double ditto on using ring terminals.
Another option would be to mount it similarly to the BMW mount for a Powerlet socket. Part 4 in this diagram.
DIY Starter Switch Dbvis-3045358271077770284
5Back to top Go down   DIY Starter Switch Empty Re: DIY Starter Switch Sun Sep 24, 2017 2:33 pm
uhoh7
uhoh7
Thank you for replies.
I'm using 100% copper 12 gauge speaker wire with heavy insulation. The best in my workshop Wink I will monitor the insulation to be sure it's not melting.
Thanks for idea attach to rings and connect them to the switch. I have seen so many crimped and soldered wires come loose. I put this together very carefully and then examined it closely. Originally I was going cover each side with insulation. But the sides were well separate and after I cranked the screws the attachment seemed very firm.
Per concerns here: I will inspect. Long run, I hope to find a good clean handlebar control. Smile
But to all:
While even a MX kill switch will work about 10 times in a pinch, to be reasonable:
60 amp switch.
12 gauge wire with heat resistant insulation.
Strong connections.
