1Back to top Go down   K1100 exhaust re-install Empty K1100 exhaust re-install Tue Apr 24, 2018 9:18 am
DeRodster
DeRodster
Hi All,
 Just at the cleanup stage and am thinking around the various exhaust parts to allow re-install on my K.
 I have new studs and nuts and copper washers.
I don't recall seeing any copper washer come out when I removed exhaust all those months ago, so I guess they are still stuck in the ports. Can i just jack 'em out with a flathead or should I be more cautious
Then decided to clean the exhaust and silencer with metal polish ...didn't seem to be getting too far with that idea, so moved to fine wet n dry. Worked a treat, and all those years of grot n grime are slowly coming off and showing a gleaming stainless surface. I'm still amazed at all the little blobs of road tar !!
Just at the finishing stages of rebuild and hope to be back on tarmac soon
adios
Rod
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Tue Apr 24, 2018 9:21 am
Rod
Get new rubber mounts for it, don't reuse them.
I always use wet and dry on the headers, works better than anything.
Wish we could get you over to K Fest.
3Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Tue Apr 24, 2018 10:18 am
Where the 3 front pipes run fairly parallel put a jubilee clamp around them to stop the vibration induced cracking. Tighten up all the studs a bit at a time, nice and evenly and before you start to get to the stage of crushing the copper washers put the rear mount in position and make all those bolts firm. That way you are keeping the whole system in its natural position.
4Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Tue Apr 24, 2018 11:00 am
DeRodster
DeRodster
thanks for replies lads,
 Yes, you might yet Olaf, about 150 days to go and I'll be free to do what I like ( Other 'alf permitting ;-))
Good point re new rubber mounts...hadn't thought of that in particular and I have been thinking of a new rubber gasket for rear drive unit...
On mine it's 4 pipes RickG, and they are all welded in place so no probs there. I'll have a grovel about under it later and see if I can spot any old copper rings in the ports.
Just taking my time and hopefully ensuring all is correct and in the right place, so far so good
R
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
5Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Tue Apr 24, 2018 11:30 am
The old copper gaskets never fall out in my experience.  I suspect because their diameter increases ever so slightly when they are initially "crushed" upon installation.
I've never bothered to replace them.
6Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Tue Apr 24, 2018 2:31 pm
+1 on what the Duck said.  I have never replaced those gaskets on any of my bikes and never had a leak there.
I used 2500 wet or dry on my header pipes, made them look nicely polished with minimum expenditures of time and effort.
Looked the treat...for about 30 miles.
7Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Tue Apr 24, 2018 4:20 pm
DeRodster
DeRodster
Ok on all that
Am putting 8 new studs in
Plan to use a little thread lock, though I can't imagine they'll fall out. Time will tell i guess
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
8Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Tue Apr 24, 2018 4:42 pm
I didn't use threadlock...used copper paste not that tis worth a lot in there.
9Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Tue Apr 24, 2018 4:52 pm
DeRodster
DeRodster
Oh indeed, i love that copper grease....it goes on everything, except my toast....i reserve that for Kerrygold  ;-)
And i forgot to mention an obvious plus , or at least something that will ease input...the new studs take a hex drive and the new nuts are copper. I'm looking at the old ones, all rusted and nasty,  and thanking a higher being that i got them all out intact & without tooo much trouble
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
10Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Tue Apr 24, 2018 5:49 pm
I used stainless studs and nuts with copious amounts of copper anti-seize.  No problem removing them.
Speaking of copper.  Check the "copper" nuts.  The ones I bought from Max BMW were made of some mysterious magnetic copper that quickly rusted.
11Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Tue Apr 24, 2018 6:11 pm
DeRodster, the copper rings in the K1100rs were invisible to me due to soot. I got a cheap dentists type tool in the € shop and picked them out....turned out there were two sets in there. if you are buying studs make sure they are the right length (They're not the same as 8v ones).
Looking forward to seeing you "out and about".
W.
K1100 exhaust re-install Ir-log1188....May contain nuts!K1100 exhaust re-install Ir-log11
K75RTP - 1994
12Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Wed Apr 25, 2018 5:36 am
DeRodster
DeRodster
Copper nuts my eye, unless the laws of physics have changed !
K1100 exhaust re-install Copper10
Onwards and upwards, the quest continues ;-)
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
13Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Wed Apr 25, 2018 7:05 am
Of course the laws of physics have changed. This is Ireland after all! Shocked
14Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Wed Apr 25, 2018 7:45 am
DeRodster wrote:Copper nuts my eye, unless the laws of physics have changed !
Superglue.....
Can you imagine the fun I had one day when I bought a stainless steel saucepan clearly marked suitable for induction hobs then when I took it home it wouldn't work. Someone in the shop when I brought it back could not understand how it couldn't work....'its a saucepan, you put on the cooker, there is nothing in it to work' was all they kept saying. She certainly had an antimagnetic personality.
15Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Wed Apr 25, 2018 6:47 pm
Point-Seven-five wrote: Check the "copper" nuts.  The ones I bought from Max BMW were made of some mysterious magnetic copper that quickly rusted.
More tragic victims of shiny things.
They aren't sold as "copper nuts" on the MAX site. They might be a new BMW hue–Kardashian Bronze. Laughing
16Back to top Go down   K1100 exhaust re-install Empty Re: K1100 exhaust re-install Thu Apr 26, 2018 6:20 am
I have bought a few sets of these nuts and studs......'copper' is only a coating. Like brass door furniture.....'brass' is often 'brassed' as in coated steel. Always bring a magnet.
