As I have mentioned in previous posts to other discussion threads, I'm designing and building circuits to adapt the K100 electrics to aftermarket gauges.
Gear Indicator and Start Enable Board
The TGPI design has gone through a few iterations, with the current version 4.1 being based on a micro-sized Arduino processor.  This design is adaptable because of the on-board computer and can display the gear in a multiple of ways:
  • With a numeric digit using a 7-segment 0.39" LED display[/li]
  • With up to 6 LEDs, each LED representing a selected gear[/li]
  • With a direct connection to an aftermarket Koso gauge which has inputs for displaying a selected gear[/li]
  • With up to 6 incandescent bulbs, similar to the LEDs, but for a retro look when placed behind a bezel[/li]
As shown in the photo below, there is a separate 7-segment display board with a cable length of 150mm, however a custom length can be provided if required..  The intention with such a short cable is that the board and display will be together in an enclosure.  It is possible that this arrangement does not meet with your intended design.  When ordering, I will exchange information with you to understand how and where the board will get use.  This allows me to tailor the display umbilical cable to a length that suits your build.
The Gear Indicator and Start Enable Board also has circuitry to amplify and condition the speed signal coming off the rear drive. Many modern aftermarket speedometers require the use of an active inductive sensor that outputs large voltage levels (>7 volts) for the meter to work properly.  This usually means adding a magnet and aftermarket sensor to the front wheel to get that signal.  The variable reluctance (VR) sensor in the final drive of the K100 is not capable of reproducing these active signals without help.  The circuit on this board will amplify the weak VR signal from the K100 sensor, making it usable for a range of aftermarket speedometers.  This means one can re-purpose the OEM sensor and avoid adding additional sensors to the bike..  This feature means that you don't have to use the manufacturer's speed sensor and worry about finding a place to mount it.
I have developed the next version of the TGPI board (v5.2).  This version includes new functionality and a fundamental change in the design.  There is a circuit now that will condition the engine RPM signal available on the Black/Blue wire (Pin 16) of the OEM cluster, and make the signal compatible with aftermarket tachometers.  I have also included a more robust power supply onboard along with a resettable fuse and transient voltage protection.  This will result in a more robust reliable board than previous designs. Finally I have integrated a circuit on the tachometer output that adjusts the signal to make it compatible with one particularly popular Chinese aftermarket gauge.
Aftermarket Gear indicator/Neutral indicator board & 3-circuit Fuse block 2qsz3vb
The overall size of the board is 4cm X 6cm.
The change in design with v5 means that I manufacture the board based on the type of display you desire.  There are two versions of the build and unfortunately, they are not interchangeable between themselves.  That means we collaborate during the ordering process to make sure I supply you with the correct version of the board.
The tested board and LED display is targeted at $75.00 CDN plus shipping.
TGPI User's Manual Online
Speed and Tachometer Conditioning Circuitry:
If all you're interested in is just the speedometer amplifier circuitry or just the tachometer conditioning circuitry or both, it is possible for me to build only that function on the board and largely ignore the rest of the components.  The cost is significantly reduced, down to $25.00 CDN plus postage, for that board.
Aftermarket Gear indicator/Neutral indicator board & 3-circuit Fuse block Znlvet
3 Circuit Switched Fuseblock
Aftermarket Gear indicator/Neutral indicator board & 3-circuit Fuse block 20130424-acc-fuse-003
This board provides three switched 12 volt fused circuits in a compact 5cm X 5cm package for powering accessories that you add to your bike.  The switching relay is provided on the card, which simplifies the installation.  These circuits can handle up to 30A current total (the limit on the switching relay's contacts) and has a LED for power indication.  The tested board is $21.00 CDN plus shipping.
The prices are very close to my costs just for the parts that are used.  I'm making no money on these, but making them available to support the community of K-bike owners.
4-Relay Neutral Detect:
I have designed a printed circuit board to simplify the construction of the popular neutral detect circuit using four relays.  The board using through hole components which should be easy to source locally in a number of markets.  I was thinking of supplying this design in a flexible way, to meet different budgets and skill levels.
  • A completely assembled and tested circuit (first photo)[/li]
  • A kit consisting of the PCB and all parts ready to be assembled (second photo)[/li]
  • The raw PCB[/li]
The board overall is 5cm X 5.2cm in size. It will take input from the TGPI switch and output a Start Enable signal and an active-low Neutral signal whenever the transmission is in neutral position.
Aftermarket Gear indicator/Neutral indicator board & 3-circuit Fuse block WgnpLbwhSaPxCu24gWGouaFUlFRmKUSlLeEfXD4pwzT6pDpke4wFkjkCOoX-ohAek9OEzzwkL8GgtqL05-vzLQNLi5swmdG0mN2o1hL-0O8wGV5RZH2Yv4k_j17izFtnmWfG_tpbFhWAidEE6GA-NWajgGfrtxJNKkLH27RFnqRluo24YslTvFd8CAzX3zrxH6KsLTsowldGw_uCJ4xRySqDM0Ksg4Sham3jWTqrnhCE2ELBmJjgTnrkKO6NY3dxwATT0FTOoqSqSqkTif_wjF550LkfdMBhO5MKTs5uWRPGoG3YoxUH53dcQmCJK7iOGI27YmiueA-exUqfCS2reNaO3rzT7DvwEh1i9WdmHsHJJ06x74UBpp7MBKcl3opvpCcqWtOaqE5UIgykuvbm98QEJYGaABNYQ_-9JgLcTYIHnBbUi6UpBAAs-_pvlNKVpJL856lavcAa5dZQ8y6aPk3yn3mWhQuZJwDJNRF20UiQ39UB3OC2DX9nKpOnddCtmGxuxW4nCXFanX_0TGYnkikzOXC6SsYKi6YihdU83ks_QVEBcWlRH47OPJ4XzOg6SYLkUFlVRLzTRXV26IqaZS6YiyKIn48_1frGRAn3DAMu7poz87Qiqs6z=w1208-h1398-no
Aftermarket Gear indicator/Neutral indicator board & 3-circuit Fuse block BdyX2J0S_7JWB1De7shFlMei-t85Gi1nKVsAbI4geGjOarS9pKyq4RuMH1pjvNr6HRjMsGo5eMDcPyzB_zkf5lWB1VvdzK4E7k9w2lJFDJoyHm5g7eZUeK5hm8OCx9ChWxbME-ny_tr_DgFdvHJ1WUZEp0XB_DXyfECBLuLse447mp9y3yUngSMTSL0c8Gxe2smuQ7m_TDgPAoU2bJ_kcOEO-UutUjbTc-49bl_cdISmji6FAujTBXKsGkKr1rZ2iPWn5rRHRBONA3bsk8mLTS_04iplJmikDRq-6cS2gj_5bH_pt2AU5oZljBtsBRjl-0bTrpk58NdyXsT914eRvMCoBmNPFGzv7cHCiSZihzgU9k8n7V18kWEGnxBHU06SnM1AvfVww9bMC69U13gMu0_XpqiDEb7aQO9ypWsbSFdFUejiI3p3jDmQL-9nYA5T1dy96PY5qxf6FP5DlqRc2MFvYuPqevqW7JPvEGL-G9mBydRxPouiKnfwKf55d5Ce7BqrQNb4FZvC-NxVeyIGcQUdim7jDUHpk2_yXZzSo8ubvBLZKXDksAJC4ajMCiZxVxLeG9mPP7z_5lB2FRUxZzAf23J09NwtBrWJibCItO17TC6Q1XbgTIA8=w1920-h1398-no
Ghost who rides
Ghost who rides
Great work Rob, can't believe those prices! This post should be first port of call for any one going aftermarket speedo route, it would save lots of banter when guys post asking how to get them to work. Can the forum somehow highlight this since there are many posts on the subject?
Love your work and the way you freely share your Knowledge, well done.
very nice solution rob
and the switched and fused board is great as well ...
prices are great
well done .....
I would think that you have a few sales immediately and could become the "end all the drama issues that many perceive as problems for an upgrade " reference
I would be thinking world wide sales will follow real quick, once the word gets out
if I could suggest ....you need to mark it up a bit in price for the "non afflicted kpox addicts "   grin
ps. I know of a few other places to advertise this solution if you are ready for a flood of enquiries
I do suggest that a good "connect up for dummies " be included
along with a disclaimer for faulty gpi  switch applications
question though ...did you include some bleed voltage to the gpi switch ( for wetting the  contacts ) ...not obvious immediately...oops found them ...woohoo
great project
cheers !!!!
Aftermarket Gear indicator/Neutral indicator board & 3-circuit Fuse block 112350Aftermarket Gear indicator/Neutral indicator board & 3-circuit Fuse block 112350Aftermarket Gear indicator/Neutral indicator board & 3-circuit Fuse block 112350
Hi Rob
You can count me in for one of the gear displays as I'm (very) slowly gathering parts for a brick trike for my wife. I guess the question is:
Shipping to Northern Ireland?
How to pay you?
I'd prefer the indicator and the board to be unconnected (i.e. no wires) as that will give me maximum flexibility when designing the wiring loom. A connection diagram would be great help though Smile
-Dai
T3CHNO1D
T3CHNO1D
Beautiful work... been working on designing similar boards, now I don't have to,
TK
Mossy1200
Mossy1200
I am wanting one.
These look great.
PM sent.I think!!(NEWBIE).I hope.
KafeRacer
KafeRacer
PM Sent.  I will take one.
Dave Evans
'Kafe Racer'
kaferacer.wordpress.com
1990 K75RT
1985 K100 Kafe Racer
http://kaferacer.wordpress.com
squig60
squig60
Count me in also. I'll buy gear indicator X 1 with standard cable, and the switched fuse board  X 1. If you can let me know how to pay including postage to Southern Ireland, If you do Paypal that would be great.
Squig60
Mossy1200
Mossy1200
I have a problem.
I linked the photo and thread to Kiwi Biker forums and theres a lot of people wanting your boards now.
Im wondering if we might need sort out a shared freight deal to New Zealand.
You could join Kiwi Biker Forum and advertise them if you like.
I think this is a a good idea Mossy.  I was checking postage today and I can send four boards to New Zealand or Australia for the same price as one board.  It makes much more sense to aggregate shipments to distant (relative to Canada) continents and distribute locally.
Can you PM me the link to the forum thread? I searched on Kiwi Bikers but failed to find the thread.
Mossy1200
Mossy1200
I think I sent link correctly.
I have several pms also on KB site asking if they are available still.
http://www.kiwibiker.co.nz/forums/showthread.php/169399-Another-Wellington-K100-bike-mod-custom?p=1130770443#post1130770443
Its actually someone elses build thread I put your info on.
I have put the info and link up on my thread now.
http://www.kiwibiker.co.nz/forums/showthread.php/168897-BMW-K100RS-Project?p=1130770568#post1130770568
mtndv8
mtndv8
Hi Rob!
If still available I'm interested in both for a future project and mod...
Please let me know...
Thanks!
Michael
brickrider
brickrider
I would like to buy one fuse block.  Can payment be made with PayPal? Thanks.
Mossy1200
Mossy1200
We have a group of 4 now from New Zealand.
Shared freight is a good idea.
bushyintas
bushyintas
would like one of your Gear Indicator / Start Enable board,
Hope I'm not too late on posting this,
i will PM to you for details.
Regards Bushy.
Bushy
k100 RT 1988 #0095723
K100 RT 1984 into Custom Single seat.  #0024503
WandererK1
WandererK1
Hi,
Just found this, Id be very keen on 2 of the power distribution boards and kits would be fine by me...
Cheers Jeremy.   NEW ZEALAND.
17Back to top Go down   Aftermarket Gear indicator/Neutral indicator board & 3-circuit Fuse block Empty Want! Need! Fri Oct 31, 2014 1:54 pm
KJustin
KJustin
Excellent invention! I sent a private message inquiring about what I need to do to buy one of the neutral/gear indicator boards.  Hope to hear from you soon!
floyd
floyd
robmac you legend you.
ill take a fuse board if you still have any.
Any East Coast Aussies wanna piggy back on postage?
Mossy1200
Mossy1200
If ever your doing any alterations you could add a resistor circuit for the alternator light.
I have mine fitted and tested now. Works a treat.
Aftermarket Gear indicator/Neutral indicator board & 3-circuit Fuse block Sany0542
theApehouse
theApehouse
Just wanted to say thanks, received my boards yesterday!
And although I haven't installed them yet, based on the craftsmanship and board layout, I know they're gonna work perfect. Great stuff, man. I especially like that, in addition to available literature, the boards themselves are very clearly marked. Nice. Thanks again!
JonoK75
JonoK75
Hi Robmack, I'm also keen on purchasing a board.. I'm located in Sydney Australia - Is there any chance you would have any available? I've also PM's you hope to hear from you soon!! Thanks
Yes, there are boards available.  PM sent.
Mossy1200 wrote:If ever your doing any alterations you could add a resistor circuit for the alternator light.
mossy
just a suggestion ...nip up to jaycar and get some "protective circuit board lacquer"   and coat both sides if you haven't already done so
Mossy1200
Mossy1200
mossy
Will do I have a number of things need done.
I have silicon moisture guard at work also but im not sure about using it as its a bit greasy afterwards.
brickrider
brickrider
The suggestion of applying a protective coat of lacquer to the circuit board got me thinking (wondering?).  The displays deteriorate with age.  Could painting them with lacquer prevent/retard this?
I don't really understand why they die.  They are well protected inside the instrument housing, yet they seem to die in bits, as if they've been struck with something.  What's happening to them?
brickrider,
If you're talking about the K-bike's standard gear display, it is liquid crystal and not Light Emitting Diodes.  Earlier generation Liquid crystal displays do deteriorate as they age, and the displays begin to fail.  It can't be stopped by applying lacquer or other UV protective coating to the display because the cause is with the aging of nematic crystals within the display.  I understand that the liquid crystal polymers age and fail to align properly when voltage is applied.  Thus they no longer polarize light properly and the segments disappear.
If you're talking LEDs, they tend to catastrophically fail, just like a light bulb.
brickrider
brickrider
Yes, I was thinking of the gear display.  I'd overlooked the obvious - that a LED and liquid crystal display are like apples to oranges.  If I understand correctly, the crystals will fail with age, no matter how they're treated e.g. exposure to sunlight, temp. swings and what not.
6strings
6strings
I'm interested if still available
6strings wrote:I'm interested if still available
I have a new design which has an on-board computer rather than using a hardware based chipset.  The new circuit boards are on their way from the manufacturer overseas so might take a little time.  I'll have 10 boards ready as soon as I received the cards and build the circuits.  The total cost will be higher because of the different components being used.
sj2000
sj2000
I am interested, please count me in. I am going to use acewell 2853, is it plug and play? thanks.
Hi,
I'll have to start building a list of potential clients, it seems.
The board will work alongside your Acewell, providing dash functions that it does not provide. The unit is not quite plug and play. Wires in the harness will have to be cut and routed to the board. New wires will have to be installed to bring outputs to new dash indicators. This requires some level of design and installation.
Count me in for one of the new ones, Rob. I always meant to ask for a second unit on the original run but eejit here kept forgetting.
33Back to top Go down   Aftermarket Gear indicator/Neutral indicator board & 3-circuit Fuse block Empty Is this available to purchase? Sat Aug 22, 2015 6:53 pm
6strings
6strings
I will be needing this device shortly , My OEM speedometer Tachometer is going to be replaced. I don't like the OEM look and I'm considering a couple of types. Anyway, what ever type I get, I would like to reatin the gear, and neutral start function. If I understand this corrctly that is what this device does? So if this is available, I would like to buy one. sornsonr@yahoo.com
EtownJr
EtownJr
PM'ed you Rob
Pedro21
Pedro21
Hi Rob ,
Just sent you an PM .
Johnser
Johnser
Could this be rejigged a bit to replace the stock selector indicator with one of those led type ones?
I'm not sure if there would be space inside the speedo cluster for an extra circuit board though now I think about it.
Below is a schematic diagram to show the connections that need to be made to adapt a Koso DL-03SR aftermarket speedometer to the K-bike.  I am assuming that the installation will use one of my TGPI boards to get the Neutral / Start Enable / speed functions.
Aftermarket Gear indicator/Neutral indicator board & 3-circuit Fuse block Koso_d10
good stuff rob
Johnser
Johnser
I got a little into this at the weekend and I'm currently working on repurposing the original board to drive an LED seven segment jobby in the stock position. Waiting for bits to arrive but it should work. In theory!
D'Ecosse
D'Ecosse
  • The raw PCB[/li]
@robmack - For the neutral detect, have you considered instead of the relay board, producing a small pcb utilizing the Logic Gate and Driver transistors?
I think that could be popular option with users
Shouldn't need the power supply as that chip will run off 12V
Thanks for everything you contribute to this site and the community!
I have not considered a design that replaces relays with solid state components. My motivation in designing it and offering it to the K100 community was that it was simple to understand and easy for a modestly skilled person to assemble, if they so chose. This relay circuit of mine is the least popular and I can count the number of units sold on less than the fingers of one hand. Although a transistor / IC based unit is tempting, I can't see much interest in the K100 community for one.
ACHC
ACHC
Hi robmack
Can you ship to my country(Thailand).
I sent PM to you. If you can ship to me please send me payment request as my paypal account.
Thanks.
