1Back to top Go down   Substitute horns Empty Substitute horns Fri Mar 27, 2015 8:06 am
I really like the sound of my horns on the RT. They're pretty loud, but when I remove my fairing and go naked those horn are just not going to cut-it. They're ugly plastic.
Found these twin chrome horns on EME this evening and thought they'd do the job nicely.
Has anyone used these? Do they sound ok?
Are there any piezo type horns/sirens that would do the job? They come pretty small these days and could be mounted discreetly anywhere.
4th and 5th listing down
[url=http://www.sirens.com.au/electronic sirens_1.htm]http://www.sirens.com.au/electronic%20sirens_1.htm[/url]
Anyone have any ideas if these are legal or not on a vehicle.
Just fishing around to see what's out there and what others have used.
 Substitute horns Austra12    Fuel:  95 Octane
2Back to top Go down   Substitute horns Empty Re: Substitute horns Mon Mar 30, 2015 5:28 pm
If there's room on your motorbike these Stebel horns are amazing!
The errant driver will think they're about to prang into a fast-moving
B Double (lorry) bearing down on 'em.
~Mac McCleary
3Back to top Go down   Substitute horns Empty Re: Substitute horns Mon Mar 30, 2015 8:20 pm
Very nice! Wow... 139dB affraid
The size is not too bad and price is good. I'll have to check the shipping to Oz.
EDIT: Just checked... These are available in Oz and a bit cheaper
http://www.onlineautoparts.com.au/buy/stebel-nautilus-compact-12volt-car-air-4x4-horn-black-139db-loud-bike-motorcycle/ZPN-01302
4Back to top Go down   Substitute horns Empty Re: Substitute horns Tue Mar 31, 2015 3:36 am
Comberjohn
Comberjohn
Check out the Stebel Magnum T80 or the later TM80.
Seriously loud and similar in size and shape to the original K bike horns.
Seems to be a popular mod for different makes.
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
5Back to top Go down   Substitute horns Empty Re: Substitute horns Tue Mar 31, 2015 7:01 am
I don't know whether newer air horns are better these days, but my experience some years back was that there was a delay from pressing the button to sound coming because of building up pressure in the air pump, though good and loud when it came.
When I use a horn, fortunately rarely in warning situations (as opposed to greeting etc.) I want instant noise.
Any personal experience from anyone on modern air horns?
6Back to top Go down   Substitute horns Empty Re: Substitute horns Tue Mar 31, 2015 8:46 am
7Back to top Go down   Substitute horns Empty Re: Substitute horns Tue Mar 31, 2015 9:53 am
Prominent in red - Does not ship to Australia.
One possible reason is that horns that play a tune are illegal downunder.  Mad
8Back to top Go down   Substitute horns Empty Re: Substitute horns Tue Mar 31, 2015 10:13 am
That's a shame.
Can't find room for them on my RT, though.
9Back to top Go down   Substitute horns Empty Re: Substitute horns Sun Dec 15, 2019 3:18 pm
volador
volador
Screaming Banshee -132 db - (BVAS) Designed for Motorcycles
Looks a bit more compact than Stebel Nautilus horn
10Back to top Go down   Substitute horns Empty Re: Substitute horns Sun Dec 15, 2019 4:40 pm
I was running a Stebel Nautilus which was seriously loud and instantaneous until it reduced itself to a squawk. I tried blowing it out and tried squirting WD40 into it to no avail. As the mob that sells them is just down the road I decided to try the more compact Magnum Low note. It proved to be loud but not as loud as the Nautilus, so I added the Magnum high as well as the OEM horn had reduced to a squeak.  The dual are close to matching the Nautilus and I can switch between one horn or both. The old Nautilus is a sealed unit and out of curiosity I broke into it and I still couldn't find out why it wasn't working.
11Back to top Go down   Substitute horns Empty Re: Substitute horns Sun Dec 15, 2019 6:11 pm
I bought a set of air horns for my K1100LT and the two horns are positions directly onto the two holes underneath, at either side of the headlight. A perfect fit. A 6" and a 9" trumpet.
I have already ordered same again for the K100RS as they will fit in there too.
139dB is good...
12Back to top Go down   Substitute horns Empty Re: Substitute horns Sun Dec 15, 2019 6:20 pm
FYI: My 2014 K1600GT came from the factory with a scooter horn.  I upgraded to these which work pretty well.
https://www.amazon.com/HELLA-007424801-Twin-Trumpet-Bracket/dp/B000COBK8A/ref=cm_cr_arp_d_product_top?ie=UTF8&th=1
13Back to top Go down   Substitute horns Empty Re: Substitute horns Sun Dec 15, 2019 8:04 pm
Michael Sydney
Michael Sydney
My K still runs twin original factory horns. I am very happy with them and they are concealed well. Sounds like an angry truck driver.
However, I have a Honda (oh, the shame) with a 'very polite single beep-beep horn. I added in parallel a cheap and nasty Chinese unit I found "on line"  for about $5 delivered. It makes an awful discordant rasping screech, not particularly loud but highly offensive..... Certainly gets attention Smile
Living in the past! K100 '83 and R65 '83.
14Back to top Go down   Substitute horns Empty Re: Substitute horns Sun Dec 15, 2019 10:43 pm
DadofHedgehog
DadofHedgehog
volador wrote:Screaming Banshee -132 db - (BVAS) Designed for Motorcycles
I have a pair (one High Tone and one Low Tone) curled trumpet Fiamm Freeway Blasters on my K75. Ditto on my Ford Fusion.
PRESENT:
1995 K75T.  I am the 3d owner.  Bought it in June 2019 with 6,242 miles on the odo.
1991 K100RS 4-valve attached to a 1990 Flexit sidecar. I am at least the 3d owner. Bought with 21,00+ miles on bike's odo.
PAST:
old (indeterminate age) Ural + sidecar
1997 Buell S3T Thunderbolt
1982 BMW R100CS
1974 Kawasaki KZ400
1970 Suzuki Titan
15Back to top Go down   Substitute horns Empty Re: Substitute horns Sun Dec 15, 2019 10:51 pm
DadofHedgehog
DadofHedgehog
[/quote]
I have a pair (one High Tone and one Low Tone) curled trumpet Fiamm Freeway Blasters on my K75. Ditto on my Ford Fusion.[/quote]
I learned decades ago on my R100S that when using the curled trumpet Fiamms, it is really important to point the trumpet's bell opening straight down onto the roadway. Otherwise, water can be forced in eventually by highway wind + rain downpours into the trumpet's coils, and then just a little water will turn the airwave sound from a blast into a burble. Actually, Mr. Rees of Rees Motors, an excellent BMW bike dealer in Shelbyville, Tennessee and a rider with 300+ thousand miles on his Brunnhilda, taught me this trick back in the early 1980s. Hope it is useful to someone here.
PRESENT:
PAST:
1982 BMW R100CS
1974 Kawasaki KZ400
1970 Suzuki Titan
