1Back to top Go down   Bike dies while riding Empty Bike dies while riding Mon Sep 13, 2010 8:00 pm
Kallack
So my 85 k100rt decided it was time to cause some trouble,
I was riding down the road and the whole bike, electrical, engine everything just dies no gauges nothing, pull over to the side of the road (after almost getting run over when bike suddenly slows down) turned key to off and back on everything came back up turned to start position (using starter button) and bike started and ran again. So turned around and headed home as I headed home it started doing it more and more with the bike moving I can take key to start position and the forward motion of the bike will restart engine and electrical will come back online but cuts out again a little while down the road.
Got home put the bike in garage and started it and now when I twist throttle in neutral with clutch in the bike dies (electrical and all) like I hit the kill switch, cycle the key and everything runs fine til I twist throttle again.
Not sure where to start on this one any ideas would be great.
Thanks,
Dave
2Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Mon Sep 13, 2010 11:37 pm
phil_mars
Does sound a bit like the plug to the FI unit is loose except for turning the throttle bit, but definitely worth double checking it is "clicked" into place.
Phil
3Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Tue Sep 14, 2010 4:38 am
After checking your main electrical connectors (including ground) you should try few simple procedures:
Start the bike with another battery (or boost it with a car battery) and try to twist the throttle when the second battery is still attached to the bike.
You may have a battery with a bad cell. I had a similar problem where the bike would start but would not stay on idle. The alternator doesn't deliver power under 1,500rpm.
I would check the ignition switch too. It may be a bad internal contact (See this page)
If you don't want to open the switch at this time, you can simply jump the 2 connections #15 (green wire) and #30 (red wire) or directly feed #15 from the positive of the battery.
Bike dies while riding Frog15Bike dies while riding Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
4Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Tue Sep 14, 2010 10:56 am
Kallack
Thank you for the replies I will try all that this evening and see if it changes anything.
Since I'm asking questions I have one about the ignition switch ( I didnt get any manuals or anything with the bike which I resurrected out of a friends backyard) in order to start the bike I have to turn the ignition switch all the way to the right (to the second postion) and once its started I have to turn it one position back to the left to get the brake lights etc to work when I'm riding. Is that normal or do I have something else messed up.
Thanks again,
Dave
5Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Tue Sep 14, 2010 11:22 am
Everything should be working in the second position.
The first position is only for the parking light (you can remove the key in the first position but not in the second one)
Maybe somebody had already open the switch and didn't put it back correctly.
6Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Tue Sep 14, 2010 11:25 am
Kallack
Crazy Frog wrote:Everything should be working in the second position.
I can remove the key in any position and the bike will still run (once started) no matter the key position I have to use the kill switch to actually turn the bike off so I must have a problem in the switch too.
7Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Tue Sep 14, 2010 12:04 pm
Ajays
Ajays
Kallack,
Manual for your bike is on Bert's (CrazyFrog) download page.
Go here for some sound advice on ignition cleaning.
http://www.easternbeaver.com/main/stuff/bmw_tech/ignition_switch/ignition_switch.html
BTW, have you ensured you have a good earth?
Finally, hold your main plug in with a tie as I have after a similar experience.
Cheers Ajays
OOPS sorry Bert, I hadn't checked that this was covered by you.
8Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Tue Sep 14, 2010 12:07 pm
I was just starting to type my answer and see that Ajays replied too.
I would start by opening the switch and check if nobody had previously messed around with it.
This maybe your only problem.
Good luck
Bert
9Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Tue Sep 14, 2010 7:59 pm
badgerdid
badgerdid
I had the same problem, i cleaned the terminals on the ignition switch and everythings been ok since.
When it dies just quickly turn the key to off then back on and it should carry on.
Instructions to strip the ignition down and clean are in the download section i believe.
10Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Tue Sep 14, 2010 8:33 pm
Phil Mars just sent me a copy of the riders handbook and this is what they say about the ignition switch:
Bike dies while riding Igniti10
This K100 rider's handbook is now posted in the download section.
Thanks Phil for this valuable contribution. cheers
11Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Wed Sep 15, 2010 12:11 am
Kallack
Yup thats not the way my ignition switch was working at all. So I pulled it out and found that someone had cut some leads and spliced some others together so I am ordering a new switch tomorrow we'll see if that fixes the problem thank you everyone for your help and if this doesnt fix it I will be back asking questions again, lol.
12Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Wed Sep 15, 2010 12:12 am
Kallack
Oh and Im going to download the rider handbook as well thank you MR. Mars
13Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Wed Sep 15, 2010 7:16 am
phil_mars
My pleasure but as with most things on the internet I managed to download it from some other nameless kind soul who thought to make it available.
Phil
14Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Sat Oct 09, 2010 9:38 am
Haybartender
I had the same symptoms on my 87 K75. I also was going through what I thought were batteries (both cheap and BMW's - it didn't seem to matter). I finally found the ground wire FROM the battery was broken. Keep in mind it 'was' a single strand and the wire insulation appeared to hold it together and it might of even fused/welded back together from time to time due to the current load. I always jumped the bike using the battery positive terminal and frame bolt, thus bypassing my broken ground cable. That problem hounded me for years. I would have never thought to check a cable.
15Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Sat Oct 30, 2010 7:04 pm
177in70s
My 85 K100RS would die and regain life while riding sometimes as soon as 1 second, sometimes after 5 seconds. and sometimes after coasting to a stop.
This was fixed when I unhooked the big computer F1 connection and "q-tipped" each blade with NAPA Contact Enhancer CE-1 which is Stabilant 22, $70 for an eye dropper full. I also dabbed a drip on each "blade receiver" but didn't spread them open. Since then I've dabbed all eight blades on my 4 fuel injectors(great), and many other millivolt and some 12 volt connectors, relays etc. You can hear it sizzle off the corrosion sometimes.
16Back to top Go down   Bike dies while riding Empty Re: Bike dies while riding Tue Nov 02, 2010 4:09 am
Hi Folks,
A much lower cost and by some considered technically superior product Caig Labs DeoxIT is a very good alternative which can be used to treat every connector on the bike.
PS this below is from the CAIG LABS Site: -
Similarities of DeoxIT®/DeoxIT® GOLD and Stabilant:
1) They are all metal contact/connector enhancers - improve conductivity.
2) They are all good lubricants and protectants.
Differences of DeoxIT®/DeoxIT® GOLD and Stabilant:
1) DeoxIT®/DeoxIT® GOLD are excellent cleaners (without the use of solvents or aggressive cleaning agents).
Not similar to flushing type contact cleaners, DeoxIT®/DeoxIT® GOLD dissolve oxidation on metal surfaces. This is especially important on older equipment and equipment exposed to severe environments (humidity, salt, and other contaminants). Dissolving oxidation lowers contact resistance, thereby increasing conductivity even more.
2) DeoxIT®/DeoxIT® GOLD are ideal for moving and stationary connections.
DeoxIT®/DeoxIT® GOLD are designed to re-coat surfaces that are disturbed (by vibration) or connections that are re-inserted many times (edge connectors, plugs/sockets).
Stabilant is more solid and requires re-application if the connection is disturbed or changed. This becomes very important in high vibration applications (equipment and systems with moving parts, transportation, aviation, etc.).
Following any disturbance or vibration, DeoxIT®/DeoxIT® GOLD will re-coat the surface. There is also no need to treat 100% of the connection. If 80% of the metal surface is treated, the DeoxIT®/DeoxIT® GOLD will spread and seal the other 20%. In fact, if a plug is treated, but the socket is inaccessible, the DeoxIT®/DeoxIT® GOLD will migrate (along the metal surfaces only) and treat/seal the socket.
3) DeoxIT®/DeoxIT® GOLD work well with similar and dissimilar metals.
Many metal treatments require that both surfaces be of the same materials to provide maximum effectiveness. DeoxIT®/DeoxIT® GOLD are formulated to be effective on all metal surfaces, similar and dissimilar.
4) Available in many convenient applicators.
We offer many applicators for our products. Sprays are offered for convenience, as well as affording a way to get to hard-to-reach areas. Since our concentrates are very cost effective, sprays become a very convenient option. Other versions include pens, wipes, needle dispensers, etc. Many applicators are offered in 100% and 5% formulations.
For reference, when our part number has "100" in the number, that represents 100% concentrate, (i.e., D100L-25C, D100S-2, the DeoxIT® needle dispenser and 100% spray, for example).
When the part number includes a "5", that represents 5% of the concentrate and 95% of a flushing solvent,” (i.e., G5S-6, G5L-25C, the DeoxIT® GOLD spray and needle dispenser, for example).
Flushing solvents, as offered in the 5% solutions, are ideal for displacing surface contamination (oil, grease, dust, etc.) and may be required for certain applications.
5) Exceptionally cost effective to use. DeoxIT ® and DeoxIT® GOLD are considerably less costly than Stabilant or other similar polymers.
*CAIG does not recommend using any form of alcohol-derived solvent (they contain water), because these are polar solvents and conduct electricity. If the solvent does not evaporate completely, they may cause shorts. This is especially of concern when applied to porous materials (phenolic, rubber, etc.).
NOTE:
DeoxIT® GOLD (formerly ProGold)
DeoxIT® GOLD GxL (formerly ProGold GxL)
DeoxIT® SHIELD (formerly PreservIT)
DeoxIT® FaderLube (formerly CaiLube MCL)
DeoxIT® FaderGrease (formerly CaiLube MCL P20 & P40)
DeoxIT® Grease Type M260 & L260 Paste (formerly CaiLube Grease)
