1Back to top Go down   The 4 pin plug under the tank Empty The 4 pin plug under the tank Fri Jun 11, 2021 4:58 pm
yamaguzzi
yamaguzzi
The other night when I was finishing up the fuel pump job I was giggling wires to see what happened and the bike died . It was when I played with those wires from under the tank . I moved them around some and all was well again.This has always been a problem but only when I was stopped.Today while out on the interstate doing a 75 mile test ride to see if the blowing fuse problem has been solved  the bike quit at 70mph .I pulled off the road and was going to look at the fuses thinking that the pump fuse blew when I hit the starter and it started.So the 4 pin connection needs attention.I an wondering if I can just use 4 individual plug in connectors rather than this 4 pin thing . Has anyone done this?
2Back to top Go down   The 4 pin plug under the tank Empty Re: The 4 pin plug under the tank Fri Jun 11, 2021 5:11 pm
moriarti
moriarti
Hi I used the spare 4 pin plug found in the relay box to replace the old one job done  Very Happy
3Back to top Go down   The 4 pin plug under the tank Empty Re: The 4 pin plug under the tank Fri Jun 11, 2021 5:32 pm
I replaced mine as soon as it started to play up with a waterproof connector from a local electronics store. I've never had a problem with it since.
The 4 pin plug under the tank Durate14
The 4 pin plug under the tank Durate15
The 4 pin plug under the tank Durate16
4Back to top Go down   The 4 pin plug under the tank Empty Re: The 4 pin plug under the tank Fri Jun 11, 2021 7:11 pm
yamaguzzi
yamaguzzi
MartinW wrote:I replaced mine as soon as it started to play up with a waterproof connector from a local electronics store. I've never had a problem with it since.
 Thanks Martin this is exactly what I needed to hear. I looked online and found these  :
https://www.amazon.com/MCIGICM-Waterproof-Electrical-Automotive-Connectors/dp/B0829Y7TGS/ref=asc_df_B0829Y7TGS/?tag=hyprod-20&linkCode=df0&hvadid=459665449369&hvpos=&hvnetw=g&hvrand=1112038915813476605&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004511&hvtargid=pla-946404782148&psc=1
5Back to top Go down   The 4 pin plug under the tank Empty Re: The 4 pin plug under the tank Fri Jun 11, 2021 7:47 pm
I replaced mine in Dec 2017. See http://www.motobrick.com/index.php?board=8.0 As an added barrier I smeared silicone grease on the joints.
6Back to top Go down   The 4 pin plug under the tank Empty Re: The 4 pin plug under the tank Fri Jun 11, 2021 8:27 pm
yamaguzzi
yamaguzzi
Thanks again Martin I'll do as you did. I have it running good now so things like this are only going to make it better.I want to get it to the point where I can go on a long journey out west for a few months and not have any problems. I've got a year to do this and have it all tested so I'm confidant in it.
7Back to top Go down   The 4 pin plug under the tank Empty Re: The 4 pin plug under the tank Fri Jun 11, 2021 8:31 pm
Every K I have owned I have replaced that plug due to connectivity problems like you describe.
