1Back to top Go down   Plug wire options? Empty Plug wire options? Fri Sep 03, 2021 8:45 pm
BespokeVillainy
BespokeVillainy
Looking for k100 2V resistance plug wires options.
Thanks!
2Back to top Go down   Plug wire options? Empty Re: Plug wire options? Sat Sep 04, 2021 12:33 am
NGK makes plug wire sets specifically for the K bikes. I have seen them on eBay and bought a set for one of my bikes.
3Back to top Go down   Plug wire options? Empty Re: Plug wire options? Sat Sep 04, 2021 4:27 am
Dan Pete
Dan Pete
I know, wrong bike here, but...
I've heard a few different things about the wires on the early K75s. And there is lots of information out there, but what NGK plug is correct for NGK wires? both my K 75s could prolly use new!
1987 K75S Red (metallic) (575) Vin 0150375 (6/19/86) Bought 05/2021 with 53K miles.
1988 K75S Marrakesh Red (643) Vin 0151479 (08/14/1987) Bought 05/2005 with 14,500 miles. Rode till 2009 at 35Kmiles. Stored in poor shape since. Sad
1993 K1100RS Mystic Red    Parts Bike. Seems mostly complete, apparently only 9100 miles!
4Back to top Go down   Plug wire options? Empty Re: Plug wire options? Sat Sep 04, 2021 8:16 am
D7EA works with these wires that have 5K plug caps.
https://www.ebay.com/itm/233908803238?fits=Model%3AK75%7CMake%3ABMW&_trkparms=ispr%3D1&hash=item36760d16a6:g:rJsAAMXQIBBRCUs-&amdata=enc%3AAQAGAAACoPYe5NmHp%252B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSRAQR8FABHjfpFoyRlXhWmW7qaTBTrI7hBUCEfw6fBSFZ9u2Ahga3BC6DRTFy17%252Bns8aN6W3IWs4dr5H7R3n%252ByIL9pzGLz7o%252FtIVsH5feuZRsHhR9ndTBGE7RdVgm5oWpnG8q4fpPKuVJzpKhbQZqGXO%252F8PZ1wQN1UNWgwZWBKBVUITLp0bn8ILuVjSeVhvdXx0Ji7%252Ff0FUMhOSP3Esb4xVI31XhQvwYx66DipzkdLx6eUGq7cygLXmZ7us5T9irB%252FWV0zcb8AC91d9De7MMv%252BllZ%252FkfPtUVTcf2vNxHhIicX7x76OFyhewyMzbP%252FMWUKPTfBi1dA%252BmHLLDJszPxmE3r55BXSy8CnCs8jL87qzMXBco7K5pamdthl1cvd%252BjW3PjJ%252BhzgWOHGN8m866vDwyT6sE7Es1tDGFU3Xv%252BmIi6rXwAoMlW1bxYI8BY9a4NU40bTwhOHnujmPHHNUP4DFN9kC6ejhXK%252FC1U2nyzBCX5nxMx54mWF9rqwnahCnA5SRx0pkPDHEh3wKh0OhboTrRfKX6Ot5z2xu9xM4KGgZaldwmQyLGjVtvuNl0I9t0Yudut1ovLZYqBmwgYwwdUVofM1KruEtsKqIfj%252Bpk7azUnX9XyXBsRTgpiFxpPoMHHygrEvWlgzwvEotnqsT5ISpXlrmUssvjusH1I%252B2VKjxZOr6OKFiSXdKgXcePPntf4vn0ai5rgsZz1t2ihSCZgHtTtOrjhl2k%252BfMkzdL%252Fw7u2XC9TUbL1iqoSWc%252BFmQhjz0TKUyfTuM9f59LuF0QDEKiSLq6n9%252BcUZ%252B%252FHDkj%252FXMOhPBXYfbq1n3P5oQHtR85NY1KKqJsLtJhwT2lZeApk98gAQ%253D%253D%7Campid%3APL_CLK%7Cclp%3A2334524
5Back to top Go down   Plug wire options? Empty Re: Plug wire options? Sat Sep 04, 2021 8:27 am
BespokeVillainy
BespokeVillainy
It doesn't look like that seller makes a set for K100
6Back to top Go down   Plug wire options? Empty Re: Plug wire options? Sat Sep 04, 2021 9:12 am
BespokeVillainy wrote:It doesn't look like that seller makes a set for K100
You could fabricate your own set from NGK stock without resistor caps then use resistor plugs or you could just buy these and move on.
https://www.bobsbmw.com/store/product/premium-silicone-spark-plug-wire-set-for-k100-2v-models
7Back to top Go down   Plug wire options? Empty Re: Plug wire options? Sat Sep 04, 2021 9:36 am
BespokeVillainy
BespokeVillainy
I saw those last night.  I just didn't know if anyone had found a quick off the shelf cross application.
Thanks.
8Back to top Go down   Plug wire options? Empty Re: Plug wire options? Sat Sep 04, 2021 10:01 am
Dan Pete
Dan Pete
Thanks, .75! That's a good price. just what the bikes will need.
9Back to top Go down   Plug wire options? Empty Re: Plug wire options? Sat Sep 04, 2021 2:13 pm
BespokeVillainy
BespokeVillainy
I  was able to get a set for a 2001 beetle to work.  I needed to prove the theory.  Plug wires aren't the best fit but they are 6 ohms.  I got the bike running for the first time👍
10Back to top Go down   Plug wire options? Empty Re: Plug wire options? Sun Sep 05, 2021 12:05 am
11Back to top Go down   Plug wire options? Empty Plug wire options Sun Sep 11, 2022 7:20 pm
redrockmania
redrockmania
Never mind the staggering cost of original parts (if available). The offer in Australia from a BMW motorcycle parts supplier of a quality after market set for $175 before postage is a bit rich. I have ordered a new (found for $14.92) set of Bosch leads for a 4 cylinder car suitable for cannibalising. I'll leave the attached coil caps in place and cut the individual plug leads to length. I've also purchased NGK 102 degree angle spark plug caps. Total cost for leads and plug caps inclusive of postage $50. Unfortunately my visits to 2 of the biggest Australian aftermarket auto parts suppliers (Supercheap Auto & Autobarn) last week saw them only offering full sets of leads - They are no longer offering individual leads for sale. If you are patient you will find suitable lead sets and plug caps online for a good price so you can roll your own.
redrockmania
redrockmania
Further to my post 11. Going through my box of old leads I found a lead where the 90 degree angle rubber boot/connector that fits onto the coil to be damaged. An opportunity to pull it apart for inspection. The internal connector has a white hard silicone covering.
BMW original coil connectors are made by BERU. The 2 coil connectors with the same specification are:- Black rubber Part # 0 300 513 121; Blue Rubber Part # 0 300 513 105. Each boot is stamped with 1000 Ohms. If making your own leads, you can buy the correct BERU coil connectors. Look for a listing for BERU VESO 105.
Same specification alternatives are:
VAG: 033 035 281 / 058 905 455; FORD: 444 999 / 441 894; VOLVO: 269135; 674702; 269136; MERCEDES-BENZ: 000 156 45 10 / SAAB: 850 757; PORSCHE: 186 660 203 300; 616 109 981 10; 186 660 203 200; BMW: 12 12 1 355 254; BOSCH: 0356 250 010; 0356 250 14; O356 250 015; 0356 250 021.
BERU apparently is part of BorgWarner.
All plug lead coil connectors are not the same. Diameter of the rubber boots vary (some are too small to fit). Some rubber boots are too short where they push into the coil and therefore will not allow physical connection of the male wire terminal to the female HT coil terminal.
Hope this helps.
