1 New Member in Westminster, Maryland Thu Jul 12, 2012 5:14 pm
Tighthead
Good Afternoon to all,
New member in Maryland here. I have an '88 K100LT w/74k miles in the very fast Tobacco Brown color. This may come as a bit of a shock, but I'm currently troubleshooting a rough running condition where the bike bogs terribly when I open the throttle. I see similar issues all over the 'net, and from what I can tell it's definitely, without a doubt, absolutely related to the AFM.
Or FPR. Or Hall Sensor. Or fuel pump. Or a vacuum leak. Or (one of) the temp gauges. Or the EFI. Or the undertank electrical connectors. Or the four-pin connector on the right side. Good lord, maybe it's the seat cover causing it. I have double-checked and have ruled out the side cases as a potential fault.
I have been reading the forum for some time now, and it looks like there are several threads with similar symptoms--my hope is to be able to eventually contribute with a solution. Currently I'm sourcing clamps for the intake manifold rubbers I'm about to replace.
