1Back to top Go down   brake cylinder seals Empty brake cylinder seals Wed Jun 26, 2013 12:47 pm
nino
Hi, anyone with pair of front cylinder brake seals ready to sell it to me? As matter of fact i cant find the place where to buy seals only, they sell it with piston only
2Back to top Go down   brake cylinder seals Empty Re: brake cylinder seals Wed Jun 26, 2013 6:15 pm
When you find the seals only, let us all know.
Full piston is all you can buy.
Obviously someone is still making them, but the supplier must be a closely guarded secret.
3Back to top Go down   brake cylinder seals Empty Re: brake cylinder seals Wed Jun 26, 2013 6:29 pm
keefk1100lt
keefk1100lt
Do you mean the seals for the calipers or the the seals in the master cylinder?
Dunno about the caliper seals, but I do know that the repair kit for the master cylinder comes with seals pre-fitted to the plunger. AFAIK, the seals aren't available separately. The kit's bl00dy expensive, for what you get!!
4Back to top Go down   brake cylinder seals Empty Re: brake cylinder seals Thu Jun 27, 2013 1:49 am
nino
keefk1100lt wrote:Do you mean the seals for the calipers or the the seals in the master cylinder?
Its master cylinder, not caliper. I have problem with rear seal on piston. There is a posibility of repair in specialised hidraulic workshop, but not in Dubrovnik where I live. In capital Zagreb there are two very good hidraulic workshops, so I have to send cylinder to them.
I meant if some of members have only seals I can do it in my garage
5Back to top Go down   brake cylinder seals Empty Re: brake cylinder seals Sat Jun 29, 2013 6:09 pm
Johnser
Johnser
I had to buy the whole piston earlier as my front seal is torn. very annoying as the actual piston and spring cleaned up like new. it does however mean I should have a spare rear seal. If you want to take a chance on a second hand one, I'm happy to look into postage to Hrvatska for you.
