gabriel
Hi everyone
Does anyone know which size socket to use to remove the screws located at the front of the engine and frame.
The screws on my bike are the ones which are included with the engine protection bars and have an unusual shaped head.
Try photo. Could they be big Torx heads? Mine if I remember are Allen Key.
I had these bolts, for the engine protection bars, on my K100 16V and was able to use a standard socket to remove them, I don't recall the size but was nothing unusual.
Removing engine from the frame..which size socket? Ir-log10
   ;BMW; K100RS Style Black 1987 105K Km     ;BMW; K1 Black 1993 60K Km     ;BMW;  K1100RS Black 1996       ;BMW; K1 Blue 1990 25K Miles
Kyle10
Kyle10
8mm hexhead driver
Removing engine from the frame..which size socket? 8mmhexheaddriver_zps1383c3af
The bolts that attach the engine protection bars definitely are not 8mm socket head cap screws.
They are a fit to a conventional 12 point socket and 22mm from memory.
The bolts that are for the front mounts that are 8mm socket head cap screws are for the engines without the protection bars.
Removing engine from the frame..which size socket? Skrue_10
gabriel
Hi everyone.
Thanks for your replies, especially Rick and Inge.
Inge, the photo you posted is the same type of screw I was referring to.
I want to replace the screw but don't know which type and size socket I should use.
Inge, any suggestions?
I will follow up your info Rick.
Thanks.
kioolt
kioolt
I don't know the size but I believe a 12 point socket will fit it.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
