1Back to top Go down   Seat gap  Empty Seat gap Mon Apr 14, 2014 10:58 am
billtr96sn
billtr96sn
I have a large gap between my seat and tank on my Ex Police K100LT. The seat has a metal base. Is this a normal 'sign' of wear or has someone larger than large been sitting on it?
As it is the metal base, is it acceptable to bend it back into shape? Or is it new seat time?
The seat is comfortable, it is just the way it looks I dont like.
Thanks.
Something witty is supposed to go here... help!! Seat gap  Uk-log10
http://www.billsbikechat.co.uk
2Back to top Go down   Seat gap  Empty Re: Seat gap Mon Apr 14, 2014 11:25 am
a picture might help .... we have no way of knowing if what you call big is normal or not  ...
there is some gap between the tank and seat in any case ...usually with a rubber cushion at the back of the tank
there is some slight adjustment fore aft at the hinges mounting on the ducktail mounts
is the tank located properly at the rear pin rubber cusions ?
there may be a way to eliminate the sag of the seat with rubbers under the seat to mate to the frame better
3Back to top Go down   Seat gap  Empty Re: Seat gap Mon Apr 14, 2014 12:06 pm
billtr96sn
billtr96sn
I will get a pic asap.
4Back to top Go down   Seat gap  Empty Re: Seat gap Mon Apr 14, 2014 12:22 pm
billtr96sn
billtr96sn
I have taken 2 pics, but for some reason only one is uploading. Hope this shows it adequately.
Seat gap  CAM00106
5Back to top Go down   Seat gap  Empty Re: Seat gap Mon Apr 14, 2014 1:25 pm
billtr96sn
billtr96sn
Here's the other one.
Seat gap  CAM00107
6Back to top Go down   Seat gap  Empty Re: Seat gap Mon Apr 14, 2014 1:32 pm
Snod Blatter
Snod Blatter
Is your tank properly popped into its poppy things at the back? The tank looks suspect to me, not the seat..
7Back to top Go down   Seat gap  Empty Re: Seat gap Mon Apr 14, 2014 2:23 pm
billtr96sn
billtr96sn
Seems to be located properly.
8Back to top Go down   Seat gap  Empty Re: Seat gap Mon Apr 14, 2014 2:31 pm
there should be a fair bit of back pressure when refitting the tank to the locating rubbers under the tank on those two 1 cm or so pin locators (the rubbers are often found to be cut up and let the tank move around a little )
 if not, could it be that the suspension rubbers at the front of the tank are letting it creep forward ?
you can lift the tank a little without disconnecting things ....but if your trying to get to those front rubbers its hose off time ...unless they have been extended .
but take a pic of under the seat   and the frame where the seat hits could give you a clue if the seat is bent to a degree ?
mine is a plastic base version so mooves-lifts  a bit at the tank  ...(when sat on) at the front like yours .
9Back to top Go down   Seat gap  Empty seat Mon Apr 14, 2014 6:53 pm
Garyk100
Garyk100
my new seat is the same, I might put the sheep back on.
 Seat gap  Bab80712
The early bird catches the worm, but the second mouse gets the cheese
1991 K100rs16v
10Back to top Go down   Seat gap  Empty Re: Seat gap Mon Apr 14, 2014 9:15 pm
The vinyl does pull them back a bit over time but the cover on yours is wrinkled which makes me think the pan is bent back a bit. You could try to bend it forward but don't be surprised if it returns to that position because the vinyl gets stretched a lot when you sit on it.
11Back to top Go down   Seat gap  Empty Re: Seat gap Tue Apr 15, 2014 12:07 pm
billtr96sn
billtr96sn
Here is the underneath of the seat
Seat gap  CAM00109
And the frame where the seat sits
Seat gap  CAM00111
The tank is firmly located on it's spigots at the rear and the locating rubbers at the front.
12Back to top Go down   Seat gap  Empty Re: Seat gap Tue Apr 15, 2014 9:01 pm
That seat base does not look factory to me and it had very definitely been recovered.
13Back to top Go down   Seat gap  Empty Re: Seat gap Tue Apr 15, 2014 11:58 pm
To get a seat better positioned with respect to left/right & forward/back: (common issue with Corbin seats)
Slightly loosen all of the HW mounting bolts on the bottom of the seat and the rear hinge bar.  Then move the seat around to best position you can  get it and then tighten the hardware.
14Back to top Go down   Seat gap  Empty Re: Seat gap Wed Apr 16, 2014 2:45 pm
AJ.Valente
AJ.Valente
No, no, no. A gap is good. I just looked on my bike and the gap is about the same. Perhaps you may need slight adjustment, but that is all.
My bike came with a Corbin double seat, and from the looks of it (crushed rubber bumpers on the bottom) it was ridden 2-up quite a lot. Result is, almost no gap in front or at the rear resulting in wear marks on the tank and tail section.  Embarassed
When I put my new seat on it appears odd at first because it stood-up much taller. However, this is normal as it will wear-in over time (the gap will close). Trick is to recondition the seat before it begins wearing on the paint.
Hope this helps.  :@:
'98 K1200RS Marrakesh Red
My old K100 RT Pics and Mods
15Back to top Go down   Seat gap  Empty Re: Seat gap Wed Apr 16, 2014 6:25 pm
billtr96sn
billtr96sn
Thank you very much Smile
