1Back to top Go down   radiator cap ...parts missing ? Empty radiator cap ...parts missing ? Mon Dec 22, 2014 6:47 pm
hi guys ,
just noticed this today
I think there should be a gasket - rubber on the inner (lower) sealing shoulder of the radiator cap
can someone confirm this ?
might explain a few things about expansion into the reservoir
radiator cap ...parts missing ? 20141222
2Back to top Go down   radiator cap ...parts missing ? Empty Re: radiator cap ...parts missing ? Mon Dec 22, 2014 7:17 pm
Part #17 11 1 460 759.
The valves in the cap won't function properly without it, no pressure and
vacum build up....as the fluid/vapour rather takes the easiest way.
3Back to top Go down   radiator cap ...parts missing ? Empty Re: radiator cap ...parts missing ? Mon Dec 22, 2014 7:19 pm
Yes Charlie, there should be a rubber gasket there. Here's a pic of my old style cap compared to the newer style.
radiator cap ...parts missing ? Sam_0824
The gaskets do tend to swell with age, as can be seen looking at the old gasket compared with the new one.
4Back to top Go down   radiator cap ...parts missing ? Empty Re: radiator cap ...parts missing ? Mon Dec 22, 2014 7:40 pm
thanks guys what I thought
I can easily hear fluid pumping back and forwards to the reservoir just by clamping the bypass hose with my fingers
I don't think that that should happen
cheers again
ill try and make one today ...tyre tube rubber ?
oh  btw ..cleaned up now
5Back to top Go down   radiator cap ...parts missing ? Empty Re: radiator cap ...parts missing ? Mon Dec 22, 2014 7:51 pm
The gasket is higher/thicker than the grove in the cap.
If you use a material that have the same thickness as the grove,
it could be that you don't get enough pressure on the sealing surface.
6Back to top Go down   radiator cap ...parts missing ? Empty Re: radiator cap ...parts missing ? Mon Dec 22, 2014 8:21 pm
Charlie, I have a spare cap and a spare rubber gasket that's yours if you want it/them.
Crappy time of year due to gatherings/travel etc, but if anything can be organized, I will be in Bris Vegas on Christmas morning (Indooroopilly) if that helps.
7Back to top Go down   radiator cap ...parts missing ? Empty Re: radiator cap ...parts missing ? Mon Dec 22, 2014 9:19 pm
thanks inge and blakey
will look around for something
no big rush I guess, its been like it as long as I can remember    or fell out one time and I didn't notice
trust bmw to build in a little trickery
mean while ready for a start ...but no go  yet ..checking stuff ...a can of "start you barstard " might be purchased today
grin
8Back to top Go down   radiator cap ...parts missing ? Empty Re: radiator cap ...parts missing ? Tue Dec 23, 2014 6:01 pm
A new gasket is 2.5 mm thick, Charlie.
Cheers,
9Back to top Go down   radiator cap ...parts missing ? Empty Re: radiator cap ...parts missing ? Tue Dec 23, 2014 8:43 pm
thanks paul ...yep that helps
