1Back to top Go down   ABS woes Empty ABS woes Mon Jul 05, 2010 5:03 pm
SRD
After finally getting the bike started after the winter, (new fuel injection ECU), the ABS system is playing up, (please see "Warning light problem" thread).
The situation is as follows;
  • ABS and main warning light start flashing together as soon as the ignition is turned on.
  • If the ABS button is pressed, the lights stay on permanently for about 10 minutes, then revert to flashing. (Does this imply that the ECU is partly working, or is there a timer on the warning light relay?)
  • ABS does not work
  • I've connected a test meter between the middle contact of the diagnostic socket and earth and get 7 "blips", which indicates a fault with the ABS ECU
  • I've tried resetting the ECU by connecting a wire from the central diagnostic socket contact to earth, holding down the ABS switch, turning ignition on, holding the switch down for 20 seconds then turning the ignition off. No joy.
Any ideas, other than to replace the ECU? (I don't fancy a £300 bill, if I can help it). If not, any suggestions where to get an ECU? (I've looked on e-bay).
Simon
1991 K100LT
2Back to top Go down   ABS woes Empty Re: ABS woes Tue Jul 06, 2010 2:51 am
Ajays
Ajays
SDR,
If it has been standing and it was OK before, then I would clean every contact I could find in relation to the ABS. This is about the only thing that could go wrong when just standing. Also shine up the teeth pick up on the wheels.
Ajays
ABS woes Th_Kengine_gif
AJAYS
3Back to top Go down   ABS woes Empty Re: ABS woes Tue Jul 06, 2010 6:40 am
beachcomber
beachcomber
I stripped 2 K1100's down last year with ABS - on BOTH bikes the Brain connections looked like they'd been sprayed with green fur ! OK, slight exageration. ABS woes Icon_wink
In both cases the previous owners had experienced "trouble" with the ABS. Both sets worked perfectly after a good clean and lube of all the contacts.
In fact, ANY new to me Kay now gets that treatment on all the electrical contacts. Oh yes - and ABS gets stripped off and sold on! ABS woes Icon_biggrin
4Back to top Go down   ABS woes Empty Re: ABS woes Tue Jul 06, 2010 11:51 am
ssray
5Back to top Go down   ABS woes Empty Re: ABS woes Tue Jul 06, 2010 7:33 pm
I don't have ABS on my bikes and don't have any experience with it.
I found the following information on a French BMW site and translated the post.
Reading the ABS fault memory:
Find the brown/white wire on the diagnostic plug. (The diagnostic plug is a small plug with 3 wires. It’s situated on the right side between the electrical tray and the ignition/FI computer)
Plug a low intensity light (12v LED is the best) between this wire and positive of the battery.
Turn the ignition ON.
o No flashing, all is good
o 1 flash: Fault in the front modulator
o 2 flashes: Fault in the back modulator
o 3 flashes: Fault in the front sensor
o 4 flashes: Fault in the back sensor
o 5 flashes: voltage of the battery too low
o 6 flashes: Fault with ABS relay
o 7 flashes: Fault in the ABS computer
o 8 flashes: Need to reset the computer
Flashing the fault memory:
- Plug the brown/white wire of the diagnostic plug to the positive of the battery
- Turn the ignition ON for few seconds
- Turn off the ignition
- Plug the brown/white wire to the ground
- Turn the ignition ON again
- Push the ABS button on the dash for 30 seconds
- Turn OFF the ignition
ABS woes Frog15ABS woes Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
6Back to top Go down   ABS woes Empty Re: ABS woes Wed Jul 07, 2010 9:01 am
SRD
Thanks Crazy Frog,
Do you happen to know / does the website state whether the procedure for flashing the unit applies to ABS 1, which is what I have, or ABS2? I don't want to ruin the ECU by getting it wrong.
Simon
7Back to top Go down   ABS woes Empty Re: ABS woes Sat Jul 17, 2010 2:08 pm
SRD
Update: success!
Contacts cleaned, rotors cleaned and ECU flashed. ABS now working fine. 20 mile ride completed, no problems.
Thanks to all who suggested fixes; you've saved me a large bill.
Simon
8Back to top Go down   ABS woes Empty Re: ABS woes Sat Jul 17, 2010 6:07 pm
wedge
Result.
nice when it's a cheap fix
