1Back to top Go down   My Side Stand Left Empty My Side Stand Left Mon Oct 08, 2018 12:16 am
tjh1985
tjh1985
(Tried posting this under “Parts” catagory, but it won’t let me)
Lost the side stand to my recently purchased 1985 K100RT...by “lost” I mean it was there when I started my ride and gone when I ended it. Wondering if there might be a universal side stand that could serve as a replacnent or if I need to replace it a used one via eBay?
Thanks for the hellp and as a new member to the K100 family, I’m thankful this forum exsists because im going to need a lot of help....
Thomas
http://www.thomashurst.com
2Back to top Go down   My Side Stand Left Empty Re: My Side Stand Left Mon Oct 08, 2018 1:21 am
Welcome, three posts then you'll enjoy greater access. You did right to say hello first in the Member's Introduction.
You're better off locating a second hand K100/K75 sidestand as there's not much generic about the location or way it mounts. Be sure to purchase a new tapered screw to hold it on, and springs to retract it.
~Mac McCleary
3Back to top Go down   My Side Stand Left Empty Re: My Side Stand Left Mon Oct 08, 2018 1:32 am
tjh1985
tjh1985
Thanks TWB - Appreciate the wisdom, and insight to pick-up the either parts so the next one doesn’t go missing too.
Sent from Topic'it App
4Back to top Go down   My Side Stand Left Empty Re: My Side Stand Left Mon Oct 08, 2018 3:00 am
don't forget to ask if the second hand sidestand has the bush between the two fingers of the side stand attaching point ...note they wear badly when not serviced regularly ...and a promoted lean angle  will result
My Side Stand Left 9165710
also the springs for the retract function
My Side Stand Left 9164910
and the spring - stand retract shackle  part 12
My Side Stand Left Diag_4bh
no longer available in many parts lists
but an idea to the shape and form
My Side Stand Left Vorver10
good luck
5Back to top Go down   My Side Stand Left Empty Re: My Side Stand Left Mon Oct 08, 2018 5:05 am
It is a wise move to fit grease to both stands and fit one to the clutch arm if not fitted. Some stands had a plug that could be replaced with a grease nipple.
Regards Martin .
My Side Stand Left Clutch13
6Back to top Go down   My Side Stand Left Empty Re: My Side Stand Left Mon Oct 08, 2018 6:55 am
tjh1985 wrote:(Tried posting this under “Parts” catagory, but it won’t let me)
Thomas
I've moved this post to a more appropriate category for you.
Cheers.
~Mac McCleary
7Back to top Go down   My Side Stand Left Empty Re: My Side Stand Left Mon Oct 08, 2018 9:16 am
tjh1985
tjh1985
Thanks everyone for the help and for moving the post.
