1Back to top Go down   LCD clock Empty LCD clock on Fri Apr 05, 2019 5:33 pm
smoll1
Hi all
My LCD clock has lost loads segments. I have spare clock from another set instruments. Is there any way to power up clock off the bike to see if it works before I swap them over.
Can I rig up a temporary battery without damaging the clock? Very Happy
2Back to top Go down   LCD clock Empty Re: LCD clock on Fri Apr 05, 2019 5:54 pm
It only takes 9V to test it.  If you look closely you can see very small "+" and "-" printed on the back of the clock to determine polarity.
I use one of these:
LCD clock E22
3Back to top Go down   LCD clock Empty Re: LCD clock on Sat Apr 06, 2019 6:44 am
smoll1
Thanks ideal I will get a battery when I head to town. Hopefully it is a good working clock. No excuse to be late for work then though  Shocked
4Back to top Go down   LCD clock Empty Re: LCD clock on Sat Apr 06, 2019 6:49 am
nobbylon
nobbylon
My clock has a mind of it’s own. Complete digits but random time changes.
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
5Back to top Go down   LCD clock Empty LCD clock on Sat Apr 06, 2019 8:00 am
smoll1
Got a battery and checked it. You were right you can just see + and - next to terminals. the clock works fine so good result. Now have to change it over.
Thanks for advice.
6Back to top Go down   LCD clock Empty Re: LCD clock on Sat Apr 06, 2019 9:56 am
7Back to top Go down   LCD clock Empty LCD clock on Sat Apr 06, 2019 12:08 pm
smoll1
All fitted didn't take too long .work perfect. Good to be able see clock again. Thanks for all advice. Forum is great. Very Happy
8Back to top Go down   LCD clock Empty Re: LCD clock on Sat Apr 06, 2019 4:18 pm
@nobbylon wrote:My clock has a mind of it’s own. Complete digits but random time changes.
That's indicative of the clock loosing power intermittently. I would guess that it is related to the connectors which supply power having corroded and poor contact now ensues. I'd open the cluster and see if you can remove the clock module to clean it.
9Back to top Go down   LCD clock Empty Re: LCD clock on Sun Apr 07, 2019 2:30 am
nobbylon
nobbylon
Thanks, i’ll give it a try.
R1100GS Feb 1995
K100RS July 1989
R90s June 1975
R75/6 Feb 1976
F650GD May 2001
10Back to top Go down   LCD clock Empty Re: LCD clock on Sun Apr 07, 2019 11:40 am
Missing segments can be caused by poor contact between the flexible contact strips and the LCD caused by the plastic clips of the housing loosing their grip.
This can be overcome by adding some shims (the white bits) as in the picture. I used the thin card from a visiting card for my shims!
LCD clock Sam_0110
