1Back to top Go down   Clock Failure Empty Clock Failure Sat Sep 11, 2021 10:20 am
yamaguzzi
yamaguzzi
Recently I went thru my  1988 K 100 RS and everything was real good.I took her on a 2000 mile or so camping trip and she ran and still runs great but on this ride the clock would just change times all on it's own.I'd reset it and it would be fine for a few hours then out of nowhere it would be very wrong .Is there a way to fix this  or is this a symptom of a bigger problem waiting to happen? Or, is just a failed clock to be ignored ?
2Back to top Go down   Clock Failure Empty Re: Clock Failure Sat Sep 11, 2021 10:36 am
It's a failed clock. The clock is completely independent of any other component on the bike and its failure will not affect the operation of your K100.  There are a couple of buttons on the clock.  It's possible the buttons are going intermittent and need cleaning.  Remove the clock assembly and carefully clean the buttons with electronics cleaner like Deoxit.
3Back to top Go down   Clock Failure Empty Re: Clock Failure Sat Sep 11, 2021 10:39 am
yamaguzzi
yamaguzzi
Thanks , that's what I was thinking but needed to hear it from someone else.
4Back to top Go down   Clock Failure Empty Re: Clock Failure Sat Sep 11, 2021 10:51 am
Don't rule out the possibility of an amorphous, free-floating time warp. Next time it happens, carefully observe if anybody near you is wearing knee britches, a tricorn hat or a tight-fitting mylar jumpsuit with padded shoulders.
5Back to top Go down   Clock Failure Empty Re: Clock Failure Sat Sep 11, 2021 11:08 am
moriarti
moriarti
Possible ATZR syndrome (automatic time zone reset) Very Happy Very Happy Otherwise no idea hopefully just faulty clock  scratch
6Back to top Go down   Clock Failure Empty Re: Clock Failure Sat Sep 11, 2021 12:20 pm
Is the time skipping forward a couple hours(or minutes) or is it going back to 1:00?
Skipping time could be the set buttons while a reset to 1:00 is more likely to be a power connection somewhere since the clock is independently powered from the rest of the bike including the cluster. Even a momentary interruption will reset the clock to 1:00 and since the power is separate from the rest of the bike, you won't notice anything else happening on the bike.
I would start by shooting Deoxit on the big cluster connector.
7Back to top Go down   Clock Failure Empty Re: Clock Failure Sat Sep 11, 2021 2:10 pm
Laitch wrote:Don't rule out the possibility of an amorphous, free-floating time warp. Next time it happens, carefully observe if anybody near you is wearing knee britches, a tricorn hat or a tight-fitting mylar jumpsuit with padded shoulders.
I hate it when the leprechauns try to keep up with the times.
8Back to top Go down   Clock Failure Empty Re: Clock Failure Wed Sep 22, 2021 6:12 am
Hi, back in 2012 I repaired a clock with a shim to increase the pressure on the contacts to the LCD, have a look here:-
https://www.k100-forum.com/t4319-clock-repair#44108
9Back to top Go down   Clock Failure Empty Re: Clock Failure Thu Oct 28, 2021 6:52 pm
yamaguzzi
yamaguzzi
yamaguzzi wrote:Recently I went thru my  1988 K 100 RS and everything was real good.I took her on a 2000 mile or so camping trip and she ran and still runs great but on this ride the clock would just change times all on it's own.I'd reset it and it would be fine for a few hours then out of nowhere it would be very wrong .Is there a way to fix this  or is this a symptom of a bigger problem waiting to happen? Or, is just a failed clock to be ignored ?
 After forgetting all about this non problem last week the clock mysteriously came back to life and is keeping time after being dead for over a month. Go figure !
10Back to top Go down   Clock Failure Empty Re: Clock Failure Thu Oct 28, 2021 8:26 pm
Shep
Shep
As we age, whether it be man or machine we sometimes need a little time out to rest and get ready for our next adventure.
11Back to top Go down   Clock Failure Empty Re: Clock Failure Thu Oct 28, 2021 8:37 pm
If you remove the clock from the mounting the array of contacts can be cleaned with an eraser or Deoxit can often work. I have revived 2 clocks like that but be gentle.
12Back to top Go down   Clock Failure Empty Re: Clock Failure Fri Oct 29, 2021 1:03 am
RicK G wrote:If you remove the clock from the mounting the array of contacts can be cleaned with an eraser or Deoxit can often work. I have revived 2 clocks like that but be gentle.
+1  I did the same thing to one of my clocks with Deoxit and a Q-tip.  Gentle is the key.
13Back to top Go down   Clock Failure Empty Re: Clock Failure Fri Oct 29, 2021 9:53 am
yamaguzzi
yamaguzzi
 Thanks , next time I'm in there replacing bulbs I'll clean things.It's not worth the effort just for the clock and besides , it's working again now correctly for a couple weeks so far . I just thought it was strange how it came back to life after a month or more of being dead and now keeps correct time .
