1Back to top Go down   Gauge issues Empty Gauge issues Tue Apr 30, 2019 5:08 pm
Martcarl
Martcarl
Hello!
After some hours of measuring, thinking, testing and talking to members on this forum I now try to describe my problem here to see if anywone have experience this peculiar problem before.
I started in November -18 to build a scrambler of a K100 RS-88, and it will soon be ready for the road. However, I have now a problem whit the aftermarket speedometer gauge (Velona Daytona) which behave strange when the engine is running.
The speedometer gets signals from the rear wheel as it should and register incomming signals when the ignition is on and I manually spin the rear wheel, but when the engine start the incoming signals rushes away even thougt the rear wheel is still.
To isolate the problem I dissconected all of the cables not having anything to do whit the speedometer function (horn, turn signals, tacometer, gear cables etc) from the TGPI V5 board (Thanks to Robmack) but still I get this strange behavior in the gauge.
So I still get this problem even if I only have connected the
1. speedometer in
2. speedometer out
3. +12 V
4. Ground
If someone has ideas about what can cause these phenomena then I am grateful for all the help I can get. Is the gauge mabye defective?
I have tried to reroute the cables (thanks for the tips robmack) to aviode interference, but with no success.
In the video below you see the speedometer in setup mode counting signals from the speedsensor. The rear wheel is still but a lots of signals is registered.
BR/Martin
2Back to top Go down   Gauge issues Empty Re: Gauge issues Wed May 01, 2019 12:43 pm
Stumpy
Stumpy
Have you tried an external power supply? Use another battery for power, not connecting to the bike, if the speedo works then you will know it has something to do with the power feed from the bike.
3Back to top Go down   Gauge issues Empty Re: Gauge issues Wed May 01, 2019 2:54 pm
tinyspuds
tinyspuds
I only ask because you haven’t mentioned doing it, have you run the calibration set up? I think these gauges are a bit random until that’s done...
4Back to top Go down   Gauge issues Empty Re: Gauge issues Wed May 01, 2019 4:30 pm
Martcarl
Martcarl
Stumpy wrote:Have you tried an external power supply? Use another battery for power, not connecting to the bike, if the speedo works then you will know it has something to do with the power feed from the bike.
Hmm. Can of course be woth the shoot. Do you mean I just connect an external battery to the TGV5 board?
5Back to top Go down   Gauge issues Empty Re: Gauge issues Wed May 01, 2019 4:45 pm
Martcarl
Martcarl
tinyspuds wrote:I only ask because you haven’t mentioned doing it, have you run the calibration set up? I think these gauges are a bit random until that’s done...
Yes! When I try to do this setup I see this hysterical frequency from the speed sensor. The sensor should give 6 signals per revolution of the rear wheel if I have understand it correctly. I get maby 20 signals per second even if the wheel is still when the engine is running. If the engine is off it works as it should.
I have now also find out that the sensor is picking upp signals also when I remove it from its position (still connected). I just need to hold it near the frame to get this phenomenon with the "fake signals".
Was doing some ground measuring between the battery negative and the frame this evening. All measurements showed at low ohm numbers (0.1 - 0.7 Ω)
To be continued....   study
6Back to top Go down   Gauge issues Empty Re: Gauge issues Wed May 01, 2019 8:36 pm
Martcarl wrote:The speedometer gets signals from the rear wheel as it should and register incomming signals when the ignition is on and I manually spin the rear wheel, but when the engine start the incoming signals rushes away even thougt the rear wheel is still.
Are you using resistor spark plug wire, or resistor spark plugs?
7Back to top Go down   Gauge issues Empty Re: Gauge issues Thu May 02, 2019 3:37 am
Martcarl
Martcarl
I have brand new Bosch X5DC spark plugs on, (bought from motorworks). If a measure resistans on the spark plug wires I get about 5 kΩ. So I guess I have resistor spark plug wire?
8Back to top Go down   Gauge issues Empty Re: Gauge issues Thu May 02, 2019 6:52 am
Michael Sydney
Michael Sydney
Is it possible you have a failed diode in the alternator/rectifier? That could send stray AC voltage around the bike possibly triggering the Speedo. Check the voltage of the alternator output with your meter set to AC.
Also, have you checked the Speedo using the heating element of a mains powered soldering iron in close proximity to the rear hub sender?  You need ignition on but not motor running. This will send regular pulses to the instrument and should display a constant speed consistent with the mains frequency.
Living in the past! K100 '83 and R65 '83.
9Back to top Go down   Gauge issues Empty Re: Gauge issues Thu May 02, 2019 7:26 am
Martcarl
Martcarl
Michael Sydney wrote:Is it possible you have a failed diode in the alternator/rectifier? That could send stray AC voltage around the bike possibly triggering the Speedo. Check the voltage of the alternator output with your meter set to AC.
Funny is that a colleague suggested exactly the same thing about the alternator just an hour ago.  This may be the evening's exercise. I plan to pull the alternator out of its mount so it is still plugged in but not spinning.
I can ofcourse also measure if there is AC voltage.
The "soldering trick" is working as it should and give me a stable result on the gauge.
Thank you for the tips!
I come back with the result tonight. (Swedish time) Very Happy
10Back to top Go down   Gauge issues Empty Re: Gauge issues Thu May 02, 2019 3:58 pm
Martcarl
Martcarl
I did connect the gauge, TGPI board and sensor to a own battery today but could not see any difference. It behaved like before, no change. scratch
11Back to top Go down   Gauge issues Empty Re: Gauge issues Thu May 02, 2019 4:14 pm
Martcarl
Martcarl
Started to measure voltage on the alternator, no AC voltage, just a perfect 13 V DC. Also removed the alternator from its position, still connected to the bike and started the motor. no change.
Gauge issues 259495
Next step (if no one have more tips) is to visit my friend and try his speed sensor.
Question to you guys who have tried the "soldering iron trick". Do you need to remove the sensor and hold the soldering iron under it to get signals or do you just need to come close to the sensor?  I think mine is picking  up signals as soon I come near the sensor.
12Back to top Go down   Gauge issues Empty Re: Gauge issues Thu May 02, 2019 4:42 pm
That's correct for the 2v engine, resistor leads and no R in the plug code.
13Back to top Go down   Gauge issues Empty Re: Gauge issues Fri May 17, 2019 11:09 am
Bumblebee
Bumblebee
 DING DING DING!!!  (Chime sound from a TV game show.)  My educated guess is that the tachometer is "seeing" ripple from the alternator.  The false signal is most likely coming in the power wire.  As said before (right above) it might be excessive ripple from the alternator with a defective rectifier. It will still charge the battery at a lower rate, but my cause problems just as you are seeing.
Try this, take a 470 uf capacitor and hook it from the power lead to ground, this might solve the problem.  This is a test, only a test see of the problem is reduced, or eliminated.
Bumblebee
http://Bugsmashers.org/phpbb
14Back to top Go down   Gauge issues Empty Re: Gauge issues Mon May 20, 2019 5:36 pm
Martcarl
Martcarl
Bumblebee
Thank you for the tips Bumblebee!
If this is the problem, shouldn't this phenomenon then also stop when I completely disconnect the generator? At one point I also tried to feed the circuit board from a separate battery, but with no success.
We will try to change the circuit board now to see if it helps.
Br/Martin
15Back to top Go down   Gauge issues Empty Re: Gauge issues Mon May 20, 2019 9:55 pm
Bumblebee
Bumblebee
Bumblebee
Br/Martin
"If this is the problem, shouldn't this phenomenon then also stop when I completely disconnect the generator?"
Yes, it should, I'll bet that there is something (interfering signal) that's getting into the gauge cluster.  You would think that disconnecting the alternator would do it, maybe the ignition system?  If this were my bike it'd have me running around in circles trying to find it.  I have had issues with the instrument cluster too!  In 31 years (how old mine is, it's an '88) things do start to have issues, but overall the bike has been solid!
BB
16Back to top Go down   Gauge issues Empty Re: Gauge issues Mon May 20, 2019 11:40 pm
Disconnecting the wiring doesn't stop the alternator from generating.
17Back to top Go down   Gauge issues Empty Re: Gauge issues Tue May 21, 2019 1:59 am
Bumblebee
Bumblebee
MartinW wrote:Disconnecting the wiring doesn't stop the alternator from generating.
No, it wont.  But if you remove the battery wire it will eat the diodes for lunch!
BB
18Back to top Go down   Gauge issues Empty Re: Gauge issues Tue May 21, 2019 2:44 am
Suzi Q
Suzi Q
20 pulses per second (post 5) is 1000rpm tickover speed-ish. Maybe the gauge is faulty and not isolating the tacho signal input from the speedo input?
Can you run the gauge with the tachometer input disconnected?
Edit: re-read the thread, and you've already tried it with tacho input disconnected. I'd still suggest that the approx 20 Hz frequency of the interference suggests an ignition/engine source rather than the alternator. If the speedo sensor detects this when held near the frame (post 5) then it's maybe a grounding issue with the ignition - the frame is carrying the ignition voltage. You could try sticking temporary extra grounding all over the ignition side of things - engine/frame/coils/battery? Pay close attention to the small-gauge brown wires onto the coils.
