1Back to top Go down   Problem with indicators Empty Problem with indicators Sun Dec 29, 2019 10:22 am
Tel
Tel
HI All
My indicators/flashers stopped working. I have traced the fault to a component on the PC board of the flasher relay. However, as the component has overheated I cannot read the information on it to get a replacement. I have indicated the component on the picture below. It's the one right in the corner of the board. I believe it is a capacitor. Any info or a picture of a good one with the writing visible would be a great help Thanks
Problem with indicators Cap_pr10
2Back to top Go down   Problem with indicators Empty Re: Problem with indicators Sun Dec 29, 2019 12:30 pm
Snod Blatter
Snod Blatter
Are you sure you can't read what's written on the side of it? It doesn't look that far gone from the picture..
All you need is the uf rating and voltage which should be written on it several times. I'd love to help you with this but sadly Inge took it upon himself to post the diagram in a resolution so small that any such detail is lost. Anyone got a better version?
3Back to top Go down   Problem with indicators Empty Re: Problem with indicators Sun Dec 29, 2019 1:13 pm
Tel
Tel
Thanks for looking at the post
This is not my unit just a good picture of one I found on the net. Mine has nothing left to read on it. All I know is that the capacitor went short circuit and overheated one of the resistors. I have changed the resistor but need to do the capacitor. I found the schematic that was posted but like you can't read the values as the resolution is not good enough. Will keep hoping that someone has one they can photograph for me even if they know nothing about electronics.
Tel
4Back to top Go down   Problem with indicators Empty Re: Problem with indicators Sun Dec 29, 2019 1:28 pm
Snod Blatter
Snod Blatter
Ahh, gotcha.
Here's a better version of the diagram, any idea of which capacitor it is?? I can't see any which have a uf rating for an electrolytic of that size but then I don't understand what 2u2 or whatever means. Would 2u2 be 2200?
5Back to top Go down   Problem with indicators Empty Re: Problem with indicators Sun Dec 29, 2019 1:35 pm
Tel
Tel
That's awesome thanks so much. I will have a look later when I get in. It took out a 75 ohm resistor connected to it so I think it might be C10 - especially as it is also directly connected to pin 14 of one of the chips.
Thanks again
Tel
6Back to top Go down   Problem with indicators Empty Re: Problem with indicators Sun Dec 29, 2019 1:58 pm
Tel
Tel
New one ordered (actually 10 new ones as I couldn't buy just one) - cost including postage £3.50 - much better than getting a new unit!
Thanks again
7Back to top Go down   Problem with indicators Empty Re: Problem with indicators Sun Dec 29, 2019 3:20 pm
Snod Blatter
Snod Blatter
Glad to help, but really you should thank the owner of this forum because that diagram is hosted on his site! Cool
8Back to top Go down   Problem with indicators Empty Re: Problem with indicators Mon Dec 30, 2019 9:07 am
Tel
Tel
Then thanks to him too!!
