1Back to top Go down   Fuel cap gasket Empty Fuel cap gasket Sat May 09, 2020 9:51 am
Snod Blatter
Snod Blatter
Hi all, last time I filled 'er up (just before the lockdown started..) I noticed this gasket has kinda melted and come away:
Fuel cap gasket A3NlJxf
I'm guessing this is also related to the distinct aroma of petrol that hangs under the bike cover on warm days. So, first off, I guess I need the most expensive seal set here because it's the only one that seems to have this seal in it. Secondly, does anyone know if I can buy that part separately? And thirdly, can I buy one from somewhere that isn't going to melt when it comes into contact with fuel??
Cheers all!
2Back to top Go down   Fuel cap gasket Empty kit Sat May 09, 2020 1:04 pm
moriarti
moriarti
Lucky you the seal on mine has turned to stalactite like rock very near impossible
to remove without damage to the seating lip.Buy the BMW kit or just make your own using good cork gasket and sticky stuff to seal it  Laughing dont know anyone that
just supplies it on its own
3Back to top Go down   Fuel cap gasket Empty Re: Fuel cap gasket Sun May 10, 2020 1:42 am
volador
volador
Petrol Tank Cap Gasket 16111456007
Gasket set Fuel Tank BMW 16119062461 Tills.de
4Back to top Go down   Fuel cap gasket Empty Re: Fuel cap gasket Sun May 10, 2020 8:16 pm
Snod Blatter
Snod Blatter
Thanks both, the expensive kit it is then..
The gasket appears to be neoprene which I would expect to melt if left in contact with petrol, but if others haven't had the issue then maybe it's a one off??
5Back to top Go down   Fuel cap gasket Empty Re: Fuel cap gasket Sun May 10, 2020 8:26 pm
Snod Blatter wrote:Thanks both, the expensive kit it is then..
It's likely to be made of Viton, a synthetic rubber that is fuel- and heat-resistant.
6Back to top Go down   Fuel cap gasket Empty Re: Fuel cap gasket Mon May 11, 2020 12:09 am
I managed to soften one up by soaking it in Oil of Wintergreen for a couple of weeks. However once removed it hardened back up.
7Back to top Go down   Fuel cap gasket Empty Re: Fuel cap gasket Mon May 11, 2020 10:10 am
Snod Blatter
Snod Blatter
Are you all looking at the one that actually does the sealing? I'm talking about the one at the back which has definitely not gone hard, more gone floppy!
8Back to top Go down   Fuel cap gasket Empty Re: Fuel cap gasket Mon May 11, 2020 10:23 am
Snod Blatter wrote:Are you all looking at the one that actually does the sealing?
I think they all do sealing for one purpose or another. Smile The "back" one seems to supply tension and cushioning to the cap in addition to any sealing duties it might provide.
Your assembly has corrosion to an extent that makes me wonder if the water drain line and the vapor line are plugged.
9Back to top Go down   Fuel cap gasket Empty Re: Fuel cap gasket Mon May 11, 2020 10:28 am
Snod Blatter
Snod Blatter
Ahhh is that what it does? I was hoping it would make more sense once I took it to bits. I guess that helps explain why they all come as a set.
Fair shout about the drain hole being blocked, I did have an occasion where I opened the cap and a load of water fell into the tank! I just brimmed her and went home.. Seemingly none the worse for it. It's always looked like that while I've owned it though, thought it seemed normal enough.
10Back to top Go down   Fuel cap gasket Empty Re: Fuel cap gasket Mon May 11, 2020 7:58 pm
volador
volador
Petrol Tank Cap Gasket 16111456007 is made of rubber cellulose material a medium/high density neoprene.
If that's the original cap gasket you got your moneys worth.
Service Bulletin 2196 February 1986
Regards Martin. probably referring to Fuel tank GASKET RING 16111453690 K75 - K1100LT scented with Oil of Wintergreen
Try a lengthy soak in 303 Aerospace Protectant to renew plasticity in rubber. It will never be new again but may become serviceable.
FYI: Rub the Oil of Wintergreen on the chest to kill the COVID-19
Fuel cap gasket 16111453690_3_B
Fuel cap gasket 16111453690_2_B
11Back to top Go down   Fuel cap gasket Empty Re: Fuel cap gasket Tue May 12, 2020 9:01 am
Something to try when attempting to revive rubber bits - Gummi-Pflege.
Funny sounding name but it seems to work. First brought to my attention by our now sadly departed member MikeP.
Read post 131 in the following thread.
Will I never learn
12Back to top Go down   Fuel cap gasket Empty Re: Fuel cap gasket Tue May 12, 2020 1:48 pm
volador
volador
Gummi-Pflege  82149407015  no luck not available from the MaxBMW fiche
worthwhile alternates
Genuine Honda 08798-9013 Silicone Grease
rejuvenate rubber seals, lubricating door seals, window channels, sunroof seals
Genuine Honda 08798-9002 Hi Temp Urea Grease
metal-to-metal contact
