1Back to top Go down   lube shock mounts Empty lube shock mounts Fri Jul 17, 2020 3:24 pm
tinyspuds
tinyspuds
After a clean up I’m going to reinstall the original hagons to my leading links. Question: Should I lube the mounting bolts? I’m seeing conflicting advice about do it or not. In the past I’ve slapped axle grease onto the bolts, which I think now has been pretty useless. I’m minded to use a bit of the high moly content lube that I use for the splines. Thoughts please?
2Back to top Go down   lube shock mounts Empty Re: lube shock mounts Fri Jul 17, 2020 3:56 pm
BMW didn't do it, why should you?
lube shock mounts Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
3Back to top Go down   lube shock mounts Empty Re: lube shock mounts Fri Jul 17, 2020 4:27 pm
Either the Optimol or copaslip. Both will help prevent corrosion and enable easier dismantling. I think Arlina believes you are refering to the rubber bushes; in which case if you need to lubricate those to reassemble the links, use silicon grease only. If your Hagons have the metal bushes in the rubbers, then see above.  If you don't grease them you will grind through the bush.
I haven't got a clue why you wouldn't use some form of anti-corrosion grease on assembly. I want my bolts to come out again, not rust in solidly. If you don't copaslip stainless bolts into aluminium, there's an electrolytic weld straight away.
4Back to top Go down   lube shock mounts Empty Re: lube shock mounts Sat Jul 18, 2020 1:34 am
tinyspuds
tinyspuds
Thanks folks.
5Back to top Go down   lube shock mounts Empty Re: lube shock mounts Sat Jul 18, 2020 4:05 am
+1 on what Dai says regarding the white Castrol Optimol. I use a lot of stainless bolts on my bikes and started using the Optimol on the threads to guard against the electrolytic action and now use it on pretty much everything and with no problems.
I only use Rubber Grease on any rubber components.
