1Back to top Go down   Wiring aftermarket handlebar switches Empty Wiring aftermarket handlebar switches Mon Mar 15, 2021 10:47 am
zedtillimded
zedtillimded
A while back a fellow member posted a how-to on wiring in aftermarket handlebar switches for bmw k75's and 100's, unfortunately I am not able to see any of the photos posted in the original forum discussion. Looking to wire in aftermarket handlebar switches on my K and any help would be great, electrical is my weakest point unfortunately
Which make and model of motorcycle are you taking the switches from?
zedtillimded wrote:A while back a fellow member posted a how-to on wiring in aftermarket handlebar switches for bmw k75's and 100's, unfortunately I am not able to see any of the photos posted in the original forum discussion.
That's sometimes one of the drawbacks when off-site photo hosts are used. From this post—which possibly could be the post to which you referred—I downloaded them from new tabs by clicking on the question marks. Here they are in order of their appearance. Each diagram is labeled at the bottom to correspond with discussion in the text.
Wiring aftermarket handlebar switches Sw011
Wiring aftermarket handlebar switches Sw111
Wiring aftermarket handlebar switches Sw211
Wiring aftermarket handlebar switches Sw311
Wiring aftermarket handlebar switches Sw412
Wiring aftermarket handlebar switches Brick_11
Wiring aftermarket handlebar switches Suzuki11
Wiring aftermarket handlebar switches Suzuki12
Wiring aftermarket handlebar switches Honda_10
Wiz
Wiz
I had my bikes controls rewired to some generic handle bar switches before I decided to go completely custom with the whole bikes electrics and engine management system. It's really not that hard to do. I recommend you locate the wiring diagram for the bike you have. If you need help you can drop me your bikes model and I can get you the proper wiring diagram. Essentially it's just identifying what wires are in the diagram and collecting them to the proper switch. Sometimes it helps to take a multi meter to the original switches to find out what the wiring is doing if something's being weird. Most of the switches are simple on off. Some go to dedicated wires on both sides, others are common grounded, but the wiring diagram explains all that.
