1 Tranny & rear end lube seepage Sat 15 May 2021 - 7:53
jjefferies
I finally am working on my list of todo's for RED my main ride for many years that has 165,000 mi/265,541Km on it. So I changed the tranny and rear end lubes. After a couple of short rides <100mi. I find that there is a slight film of lube on the bottom of the drain plugs. Not enough to form a drip but enough to get dirty. As I don't remember if I've ever checked before at this distance was wondering if this is normal. The crush rings looked good and the drain plugs are in tight. And as nearly as I could tell the tranny/rear end lube levels were good, i.e. no leaks in the past and current levels are as called for.
thanks.
J.
thanks.
J.
